What to do with an ej20?
Discussion in 'General Community' started by Demo24, Sep 17, 2006.
  1. Demo24
    Demo24 Member
    Any suggestions?
    I've been trying to take it apart now for several months, but I can't seem to find a bolt or allen wrench thats 14mm. Home Depot has every size but that one :rolleyes:. So unless anyone has an idea about how to get the piston pin covers off I guess it's time to start thinking about what I should do with it.
    I'm not entirely sure what all is still good on it. Pretty sure the pistons are shot. but the block might be savable if it had some minor work done to it. I think the crank is ok, from what I can see it doesn't look noticably damaged.
  2. Kokopelli
    take a bolt with a 14 mm head and lock two nuts together on it and use that. If you have access to a welder tack the nut on. Its what I use.
  3. Demo24
    Demo24 Member
    what I have been trying to do, but I can't find one that size. I've been to two home depots, and a lowes.
  4. Kokopelli
    try Ace Hardware or borrow one from you car.
  5. RallySTiLE
    RallySTiLE New Member
  6. Demo24
    Demo24 Member
    cool, thanks!
  7. RallySTiLE
    Hope it helps. Good luck on your project!
