turbo malfuction
Discussion in 'Introduce Yourself' started by anxiousdohc, Oct 5, 2006.
  1. anxiousdohc
    anxiousdohc New Member
    After I had replaced by FORGE bypassvalve with the stock BOV, the turbo stopped working period....I have a factory boost gauge and the niddle is resting at zero.....<~~ the gauge seems right b/c I couldn't feel the turbo kicking in.....
    what could it be??
    I appreciate your help.....
  2. Any weird sounds? Did you put the hose back up to the bottom of the BPV? Is the boost guage still plugged in?
  3. anxiousdohc
    yea everything is plugged in the way its suppose to be....no weird noises either
  4. Put the ohter BOV back on and see if that fixes the problem....ITs hard to say what it could be cause ive never heard of the turbo to just stop working
  5. crashtke
    factry unit could be like mine and recirculating all the time...mine was a slight leak. Could be a major leak. Turbo could be spooling just fine but all boost being recirculated.
  6. Just thought about that on my way to a BReathing problem call...Maybe for some reason the BPV is stuck open.
  7. goixiz
    goixiz Active Member
    even if BPV is stuck open the gauge should still move
  8. pEd
    do you have a way to verify the gauge is still good?
  9. goixiz
    hope this is not the case
    Is it possible the EGT broke and dislodge into turbo and jam it ? = no spool = no psi
    Even if wastegate is wide open there should be some psi
    Gauge broke or disconnected = no needle movement
    It should have at least vacuum if no boost
    to test it its easy take gauge out and bicycle hand pump
    ot place finger on vac line and see if you can feel vac or psi
  10. pEd
    it may be best, as well as the best option, to take it SoG (or service center of your choice) and have them look at it. You could be looking at some serious problems.
  11. Weapon
    the stock boost gauge also reads vacuum. is it always at zero? when you are at idle it should read at approximately -0.5 mpa. if it is always at zero your boost gauge is not connected properly or is broken or you could have a more serious problem. How does the car run? Have you tried to reset the ECU?
  12. gte123v
    gte123v Member
    just disconnect the boost gauge hose and blow into it with you mouth, if it's not moving, it's broken.
  13. anxiousdohc
    thanks for the help....
    I've took care of the problem...yea I had to replace the boost gague hose......
  14. Weapon
    sweet..nice cheap fix! i am glad it wasnt something more serious
  15. Alex
    word, well done :D
