Found a solution to the unbolted ebay intercooler
Discussion in 'Modifications & DIY how-to' started by jakeisajedi, Dec 7, 2006.
  1. jakeisajedi
    jakeisajedi Member
    Dec 21, 2005
    185
    Hard to see but it is zip ties. About 2 weeks and no signs of shaking, moving, or rattling!!!
  2. BrianGT
    Jun 4, 2005
    2,264
    looks jdm tite!
  3. jonnyboy0150
    jonnyboy0150 Member
    Mar 2, 2005
    712
    Well done! I just removed that bracket on the turbo side and left it bolted to only the other side. :)
  4. Weapon
    Weapon 90lbs of dynamite
    Jan 29, 2005
    6,875
    zip ties ftw!
  5. goixiz
    goixiz Active Member
    Oct 23, 2005
    1,482
    scary
    its a matter of time before boost leak
    just redrill the TMIC
  6. moose
    Feb 5, 2005
    2,969
    Looking at how off that thing is, I don't think you could easily drill it and make it stay; there'd be virtually no 'meat' to hold it in place left. Maybe a thin steel bracket that offsets the hole a bit might work though.
  7. 1ll-WRX
    Jun 14, 2005
    2,819
    How so....because the intercooler isn't bolted down the hoses would work themselves loose?.....j/w
  8. moose
    Feb 5, 2005
    2,969
    If the IC can move around a bit it can help unsettle the hoses, yeah.
  9. 1ll-WRX
    Jun 14, 2005
    2,819
    guess I've just been lucky then (my STI isn't attached to the brackets)....but I'll keep an eye out for any possible leak in the future...thanks....
  10. goixiz
    Oct 23, 2005
    1,482
    if it was me
    I would try to bend the bracket out on both sides and see if the hole lines up if not then I will move the driver side as far as possible and slot the passenger side hole (first remove the threaded tacked on nut on the bracket) slot the hole from fender side to the center line of the car. then use a bolt, washers and nut to hold it down
  11. crashtke
    crashtke Member
    Jul 28, 2006
    1,816
    That is what I did Ming. I bent the bracket a bit (does nt take much) and then drilled out the intercooler bracket a little. Worked like a charm. It is now a real tight fit and a pain in the arse to get lined up just right, but it works and no rattles.
