silencer delete any problems?
Discussion in 'Modifications & DIY how-to' started by wagon_dude, Dec 28, 2006.
  1. wagon_dude
    wagon_dude New Member
    Has anyone had any problems with the silencer delete and NO elbow? Water,debris? I just want to hear my turbo! But not harm my car.
  2. rolling_trip
    rolling_trip Active Member
    i had a silencer delete on my STi, and never had one bit of trouble out of it
  3. flip
    flip Member
    i did it on my 05 sti as well and have never had any trouble. i did notice a little bit of funny tuning while it was learning for the first say 50-100 miles but after it learned everything was perfect!!! I love it :).
  4. wagon_dude
    It was open in the fender?
  5. rolling_trip
    i had the gp moto "u turn" :)
  6. wagon_dude
    I've read the sound is not as loud with the "U Turn". But open in the fender seems a little scarry.
  7. rolling_trip
    most people just take a hacksaw to their stock ones. but i would think that would negate the effect of the factory fresh air duct. but either way you are drawing in fresh air from outside the engine bay
  8. FTZ
    Never had a problem. Did not have the GP Moto Elbow.
  9. AtlxPat
    AtlxPat Active Member
    i just took out my silencer on my 07 wrx tr 30 minutes ago, took me about 15 minutes with a friends help. I took it for a test drive and i can hear the bpv and turbo spool :ddirty: but for the elbow? idk im kinda cautious on that
  10. Demo24
    Demo24 Member
    I noticed my car was slower and I was running richer. I decided to put it back in, and now I can still hear the turbo.
  11. keeganxt
    keeganxt Active Member
    No problems either. I like the increase in noise and you can finally hear some bov. I did use a piece of stock intake tubing I had left over from the silencer delete I did on my 2000 Nissan Frontier. That probably won't help too many people but I figured it would help seal the gap from the air box to the fender and keep from sucking in water dripping from the fender walls if any.
  12. Alex
    No problems here, and had it that way for 25k or so.
  13. AtlxPat
    so has anyone here taken out the elbow and not replace it at all? or would that screw things up badly?
  14. Greg
    Greg Active Member
    I just kept the intake scoop all the way up to the inner fender and then made a custom intake with a carbon fiber airbox
  15. Alex
    I did...it doesnt really matter to be honest with you. if you want the appropriate way to do it IMO, remove the snorkus and pipe up some air with ducting from the fog light area.
  16. Demo24
    Demo24 Member
    yeah I did that at first, then I put a dryer exhaust tube to connect the two. Then I realised I was getting some moisture in the tube during heavy rains, so I took it out. Also figured it was probably disruping the air flow due to the rough ridges inside.
    It will get pretty loud.
    Interestingly now that I know what to listen for, it's quite noticeable to me and Im stock again.
  17. sti-mike
    sti-mike Member
    Thats exactly what I did, I didn't notice a big difference but you can really hear it in the cabin..
  18. Bolderer
    Bolderer Member
    I had mine like that for a while. I even took it one step further and added two pieces of 3" PVC;one 90 degree elbow and one 45 degree elbow. It ended up being pointed toward the front of the car inside the fender well, plenty high enough to not have the water intake issue. It worked great but eventually I just wanted to hear my turbo more and decided to install a K&N typhoon. So far I have had nothing but good results, both in my ears and in my arse. I personally am sold.
