Crossthreaded Lugs????
Discussion in 'Modifications & DIY how-to' started by derek13, Feb 4, 2007.
  1. derek13
    derek13 New Member
    Sep 9, 2006
    7
    Has anyone ever had this happen to them? Is it even possible? I recently got new rims and in order to have them clear the brembos in the front I needed 1/4 in spacers. No problem except that with the spacers in the back I was getting some rubbing. So I decided to take the spacers out in the rear until I can source 1/8 spacers and fix things. The passenger side tire goes well then I switch to the drivers side and loosen up the lug nuts. 3 come off no problem the other two go about 2 1/2 turns and will go no farther even with a pretty big bar for extra levrage. Did the tire shop cross the threads or what?
    Derek Murray
  2. Nitro
    Nitro Active Member
    Nov 4, 2006
    997
    yupp that sounds like it........i see some new stud replacements in your future:eek:hnoes:
  3. gte123v
    gte123v Member
    Apr 23, 2006
    310
    yup, it happened to me once. I just torqued the lug and snapped the stud, so then I had to get a new stud punched in along with a new lug.
  4. Alex
    Its somewhat common. Just take a rubber mallet, hammer the stud out, replace and you're good to go.
  5. clemsonscooby
    Dec 13, 2005
    1,536
    #5 clemsonscooby, Feb 5, 2007
  6. Slowsoul
    Slowsoul Member
    Sep 18, 2006
    494
    I wouldn't call it "easy" definately tries your patience.
  7. Nitro
    Nitro Active Member
    Nov 4, 2006
    997
    u got that right........i had to do 3 on my wife's Hyundai Tucson:wtc: took me all day .........i had to remove this stubborn brake dust sheild too..............grrrrrrrrrrr
  8. clemsonscooby
    Dec 13, 2005
    1,536
    You don't have to remove the brake dust shield or anything on the Subaru. The only thing that sucks is getting the center brake rotor nut off to remove the rotor. Once that is done, with a long pipe, your good to go.
  9. Alex
    Hmm, on mine i just undo the nuts and I can pull the rotor off. The axel nut holds the hub in...?
  10. keevo54
    keevo54 New Member
    Sep 15, 2005
    28
    Thats how my evo is. I broke a stud tonight doing a tire rotation, so I have some work to look forward to doing when the stud comes in.
  11. clemsonscooby
    Dec 13, 2005
    1,536
    Yeah, axle nut holds the rotor in. Advance auto parts or wherever you shop will carry the stud. No need to wait to ship something.
    #11 clemsonscooby, Feb 26, 2007
  12. Alex
    Oh, sorry, I missed HUB thought you were talking rotors...
