is it normal?
Discussion in 'Modifications & DIY how-to' started by tuan, Mar 5, 2007.
  1. tuan
    tuan Member
    Jan 8, 2006
    158
    that i put 4 1/2 quarts of oil in my car, turn in on for 5 min then let it rest for 10 min then pull the oil dipstick out and it only show that its full half way?
  2. Kokopelli
    the difference between the low mark and the full mark is not very much. I think it may only be a half qt.
  3. emstraumajunke
    Aug 22, 2005
    775
    Did you fill the filter first?
  4. tuan
    tuan Member
    Jan 8, 2006
    158
    yeah i filled the filter first
  5. emstraumajunke
    Aug 22, 2005
    775
    I guess all your lines were dry and its pumped the oil back through them causing it to drop 1/2 a quart.
    If your car don't smoke and there's no puddle under the car then I don't think its much to worry about. I check my oil every other fill up so I never really worry much about it unless I see my oil pressure drop and smoke start flowing out from behind my car. well no more then usual when WOT.
  6. kevingroover
    kevingroover Member
    Nov 18, 2004
    58
    all you need now is 1.21 jigawatts
  7. kevingroover
    kevingroover Member
    Nov 18, 2004
    58
    let me know if you can determine when and where a bolt of lightning is going to strike of if you get ahold of some plutonium because I would love a copy of grey's sports almanac
  8. tuan
    tuan Member
    Jan 8, 2006
    158
    ^^^your helpful
  9. SonicBoom
    Nov 1, 2004
    2,265
    My STI's almost 5 quarts....
  10. tuan
    tuan Member
    Jan 8, 2006
    158
    damn lying ass owners manual
  11. clemsonscooby
    Dec 13, 2005
    1,536
    Yeah, its supposed to be 4.8qt exactly. No sweat though, the extra .3qts not in the engine won't destroy anything. Our cars are always losing oil. I think it has to do with the way the boxer engine is sealed and the way the pistons are moving. Not completely sure though. I can never tell how much oil I have in the tranny or the engine.
  12. keevo54
    keevo54 New Member
    Sep 15, 2005
    28
    It takes a while to get all the way in the filter and some of your lines have been drained. Its normal to change a little and the difference between the high and low mark is very little.
  13. thebigph
    thebigph longing for another subie
    Mar 30, 2006
    290
    well if you changed your oil filter as well it should have taken more but if not that sounds about right. i had the pleasure of screwing up and oil change once and got oil everywhere in the engine bay. it started burning and i thought i screwed up my car big time
