Retrofit is damn near done :)
Discussion in 'Modifications & DIY how-to' started by Alex, Mar 15, 2007.
  1. Alex
    Almost done, just a few things I want to touch up stylistically ;)
    This photo may appear confusing at first, but this is the method for properly aligning projectors. Now, the somewhat "dashed" line is the height from the ground to the center of the projector itself. This is where the light would be if you were right against the wall. In order to align these, you have to have the car approximately 25ft from a wall on relatively even ground. Beneath the first dashed piece of painters tape you will see a second. This is approximately 2.5" beneath the one above it demonstrating the DOT legal cutoff point. What does this mean? In short, at 25 ft, the cutoff of the projectors needs to fall between 2.1 and 2.5" inches to be legal (not blind people). It goes without saying that lights are aligned based off the left light, not the right. The 2 pieces of vertical tape represent the center of the kick, or where you see the lower portion of the cutoff slant upward to the higher portion. The two pieces of tape are at a specific distance, in this case they represent the distance from projector to projector on the car itself. You'll notice I have set my right lamp slightly to the right. I am doing this as a safety feature. The output of the lights is so substantial that I wanted to throw a small amount further to right to help me spot an animal, person, whatever potentially running out into the street at night.
    Now I think I told some of you I did the color mod (also known as the washer mod). What this effectively does it tilt the lens of the projector upward a slight slight amount (approximately 2 #8 washers). This creates an intense range of blues at the cutoff. This is purely aesthetic and has zero effect on the output of the light itself.
    For those of you that didnt make it out to the Pool Hall g2g, you didnt see the lamps on the car. Here's a closeup snap earlier tonight while I was aligning everything.
    I'm positive this comparison is what most of you have been waiting for. This is a straight comparison of the OEM STi HIDs versus my TSX retrofit :D The difference is night and day, both of these photos were taken with the same camera and simply cropped / resized. It goes without saying how poor the light output is on a WRX compared to these two.
    Here are some misc. photos. This part of the parking deck isnt even close to being level, hence how the beam points downward prematurely.
    Interested in your very own retrofit? Contact 10th St JDM!
    #1 Alex, Mar 15, 2007
  2. 5spdfrk
    5spdfrk Active Member
    Jul 27, 2004
    1,007
    Good luck man, and keep us updated!
  3. Alex
    I found the pictures of those bugeye lamps mounted, you interested?
  4. 1ll-WRX
    Jun 14, 2005
    2,819
    ooooh yes please :ddirty:
  5. wrxin8or
    wrxin8or Mullitt
    Feb 7, 2005
    4,190
    yeah lets see them
  6. Greg
    Greg Active Member
    Apr 16, 2006
    1,714
    I don't remember who it was, but there was someone at the dent&scratch G2G that had this done already... I think it was a silver wrx...
  7. Alex
    That would be JJan12 most likely, these are his old lamps.
  8. Alex
  9. Deke
    Jan 28, 2006
    2,694
    I likey. So how much would it likely be to do that? Cheaper or more expensive than a set of edm's?
  10. 1ll-WRX
    Jun 14, 2005
    2,819
    how much to sign up?
  11. Alex
    How much do EDMs run? Also the cost varies substantially on the type of projector you want.
    Its like I said, give me a month or so of playing around with these and Ill have a nice solid backing to hook you guys up :)
  12. Deke
    Jan 28, 2006
    2,694
    around a grand, depending on where you get them. Those aren't for the HIDs though. I'm not really on the market right now (there is at least $2000 worth of other things I'd like to do first). Just curious.
  13. rexrocker
    Oct 8, 2004
    1,558
  14. Alex
    Yuh, Ill do it for under a G, dont worry.
  15. monk
    Feb 1, 2005
    2,074
    really nice work man ;)
  16. Alex
    So, should I throw one of these in? :) honestly, I am not a huge fan, but its certainly cool and quite different. Also, I'm quite positive if I had these, and everyone could see them up close, I'd have a few of them interested in an install.
  17. baddriver
    baddriver Active Member
    Feb 22, 2006
    836
    I like the BMW angel-eyes look on BMW's but I'm not sure how good it would look on a teardrop Impreza.
    How do they look in the assembly in daylight?
  18. Alex
    Ill grab some photos for you :)
  19. Alex
    Here are a few in the tear drop housings...
    These pictures are of Caesar's STi.
    #19 Alex, Mar 17, 2007
  20. 1ll-WRX
    Jun 14, 2005
    2,819
    damn....mad sexy!!!!!
  21. nsvwrx
    Oct 8, 2005
    2,726
    HOly shit nice
  22. SoFlaAutoSports
    Feb 8, 2007
    234
    SHAZAAAM!!!!! lol..yeah i want a set minus the red outline....
  23. Alex
    Haha, told ya so :p
  24. Greg
    Greg Active Member
    Apr 16, 2006
    1,714
    I wouldn't mind doing that also... It'll also give a chance to seal the pass. side up a little better
  25. LightWerkz
    LightWerkz New Member
    Mar 17, 2007
    Here are some more of the bugeyes mounted...
  26. Alex
    gracias Caesar ;)
  27. pEd
    Mar 5, 2004
    2,460
    Wow.... those look nice!!
  28. Slowsoul
    Slowsoul Member
    Sep 18, 2006
    494
    Whatevah! That red outline is DOPE!
  29. 5spdfrk
    Jul 27, 2004
    1,007
    Thanks for posting those up! It's a bit odd looking imo, maybe w/o the silver trim ring around the projector it would look better. More than likely, I would rather get the EDMs and send them to you for a HID upgrade.
  30. LightWerkz
    Mar 17, 2007
    Why get the edms when ther jdms are cheaper and easier to find? :wavey:
  31. 5spdfrk
    Jul 27, 2004
    1,007
    I guess you're right...considering I would be changing the projectors out anyways, I guess the cut off wouldnt matter at that point, huh? Or would you still have to modify the cut off?
    The reason I said EDMs is because I have a family friend who lives in England.:wiggle:
  32. savsuby
    savsuby Member
    Apr 10, 2006
    487
    The lights look sweet. I would love to get my 05 done one day.
  33. LightWerkz
    Mar 17, 2007
    Correct, after the retrofit you wouldnt be able to tell jdm vs. edm.
    You would the same light output and cutoff as a tsx.
  34. Brian
    Brian Active Member
    Mar 29, 2005
    1,236
    That's pretty wild looking. I've always liked the halo eyes.
  35. 5spdfrk
    Jul 27, 2004
    1,007
    Cool, thanks for posting!
  36. 7wolf
    7wolf Member
    May 28, 2005
    248
    i wonder if the halo eyes are one size or can they be adjusted to fit into a stock bugeye lamp w/o the projectors? whould that look stupid? the vision i have in my head looks cool but that should tell you something...
  37. xpsi
    xpsi Member
    Jul 31, 2006
    138
    I would have gotten the 04-05 sti. :/
  38. Alex
    Nah man, I'd be more than happy to work with you to try it. Send me a PM if you're interested. They come in a few different sizes, 3 to be exact--we'll call them small, medium and large for simplicity's sake.
  39. Alex
    More pics to come in a few minutes but I finally got around to pull Andy's old lights apart and removing the projectors. In other news, no need for an MRI, ankle is doing better (but then again, the intensity of my pain meds has more than quadrupled).
    What ya see here is a TSX projector with a clear lens. What's a clear lens you might ask? Well, its exactly as it sounds. Lens' for these things are made of glass (I would imagine that plastic isnt too far off though). If you own an 06, you'll notice that your lens's are not clear. The majority of OEMs are equipping their US production vehicles with textured lens. Why? Americans apparently do not like crisp and clean things, they must be all sorts of fucked up with patterns and such. As an 06 owner, a pleasant upgrade for you would be to get a set of clear tsx lens'. Naturally, this is something 10th St will be offering quite soon. If you're interested in improved clarity, sharper cutout, increase colors and an improved output just let me know ;)
  40. Alex
    LED flashlight through the tsx lens. Look at the crispness :)
  41. Trey
    Trey Active Member
    Mar 20, 2005
    1,322
    Halos look at home one a BMW, anything else looks like a ghetto show car IMO. ;)
  42. Alex
    We'll see how it turns out. If I dont like it, this setup will not be hard to resell ;)
    Some photos from today's work.
    It pays to be quite patient with this, and at this point, there is some trial and error involved. However, things are progressing nicely :)
    #42 Alex, Mar 23, 2007
  43. LightWerkz
    Mar 17, 2007
    Some trial an error? be ready for alot to come then...
  44. Alex
    It was no big deal, by trial and error I meant cut a whole, oh look its too small, widen it. Done.
  45. Alex
    my mint e46 shrouds were jsut delivered, cant decide if I want to go for the chrome look or go darker...
    #45 Alex, Mar 28, 2007
  46. miloman
  47. monk
    Feb 1, 2005
    2,074
    A-MEN
  48. Silver Surfer
    Silver Surfer Member
    Dec 19, 2006
    214
    Hey Alex, any pics of the progress?
  49. Alex
    Yes sir, I had posted some in my journal. Let me update this thread ;)
    Tested them out yesterday, I'm aiming to be done by the auto-x Saturday. Let me simply say that even with the fresnel lens, the output is substantially greater than the OEM HIDs :p Cant wait to throw the clears in.
    #49 Alex, May 10, 2007
  50. Cool_____
    Looking good man! Keep it up!
