Swapping '04+ 5 Speed WRX tranny into '02 WRX
Discussion in 'Modifications & DIY how-to' started by Jake, Mar 23, 2007.
  1. Jake
    As the title states. I'm looking for an '04-'07 5 speed tranny to put into my '02 WRX. Mainly because I know those MY trannies are a little stronger than my stock '02 i just blew the front differential in. I know they are significantly stronger but any strength is a good temporary fix until i swap out the gears which I will hopefully do in the next year (coupled with an STi block). Anyways, my question is this: what, if anything do I need to make these drop in. SOG will be doing the work, and I would assume that they would know, but i just wanna get a head start and start looking around and making sure I have everything I need so I can get my car back ASAP. Thanks in advance.
    -Jake
  2. calmnothing
    calmnothing Shlimp Flied Lice
    May 10, 2005
    1,691
    04 and 05 will bolt right in. 06-07 will need a few complicated gadgetries. The speed sensor is no longer located inside the tranny with those years.
  3. Jake
    good to know thanks. i have found some good deals on a couple 04-05 trannies. just wanna make sure.
  4. Alex
    when you thinking of having this done?
  5. Jake
    its at SOG right now. i just have to wait to hear from the insurance adjuster. as soon as he writes me the check i am gonna buy one. so within the next couple of days.
  6. 7wolf
    7wolf Member
    May 28, 2005
    248
    are the 04-05 trannies really that much stronger than our bugeyes? and if so, why?
  7. Demo24
    Demo24 Member
    Mar 2, 2006
    846
    not amazingly stronger, but its generally considered to be. The 03's added some sort of pressure release(can't remember exactly what its called), which seemed to help some. Then the 04-05's got wider gears, which I believe are considered to be pretty close to the RA gearset.
  8. Jake
    yeah, i know its not a huge difference. but like i said its just a temporary advantage until i do some major work within the next year....
  9. Jake
    found an '06 tranny that might be on its way...
  10. longfury
    longfury Active Member
    Aug 31, 2004
    1,198
    The 06-07 center diff is 1:1 where the 02-05 is 1.1:1.
    This means that the front and rear diffs are different ratios. ~3.9F/3.6R for the 02-05 and ~3.7 front and rear on the 06-07.
  11. Jake
    yeah its a complete swap, meaning it will have a new rear diff. and all axels. also supposedly they change to a push type clutch instead of a pull type (or maybe its vice versa), but this setup i'm buying has the new clutch, flywheel and pressure plate as well.
  12. calmnothing
    May 10, 2005
    1,691
    Good time to upgrade things like the mounts n bushings and other performance things. 06 also has better syncros for for 1st and 2nd. They feel nice.
  13. Jake
    yep yep, i've been shopping for random whiteline bushings. problem doing one or two every other paycheck or something to as to not take a big hit. i'll be hurting after this....
  14. Jake
    ok the '06 is on the way. SOG is doing the swap plus some minor brake upgrades. i'm just ready to have my car back!
  15. pEd
    Mar 5, 2004
    2,460
    good to hear that you got something that'll work for you.
    Maybe now you'll actually be able to drive your car around for more than a month without something else breaking. :)
  16. bluetwo
    bluetwo Active Member
    Feb 21, 2006
    1,512
    The 06 trannies are way better. But even they have issues like not going into 1st when moving even with double-clutching especially if the fluid is cold. At least that's been my experience. But it seems like as soon as you warm it up it works a hell of a lot better. I'm going to be upgrading to a synthetic fluid when I do my first change, probably Redline I guess.
    I definitely suggest upgrading the mounts because I really get tired of all that movement in the stick. It just doesn't feel like a good quality setup, but of course there are things you live with. Like the movement and the way that loud ass flywheel boldly pronounces every little bit of driveline noise! Lol. :D
  17. Jake
    Yeah I don't mind the road noise or vibration or harshness. I will eventually upgrade all the mounts and bushings. But for now I'm just happy to get it back.
  18. Jake
    bump for a pic of the setup i got. got all this for right at 2200ish shipped.
    oh, and the driveshaft was included too, just not pictured...
    #18 Jake, Mar 29, 2007
