CEL! help me pass emissions!
Discussion in 'Modifications & DIY how-to' started by Mad Mallard, May 26, 2007.
  1. Mad Mallard
    Mad Mallard the mad mallard
    Mar 15, 2005
    1,571
    4
    Wasn't sure where else to post this for help... But i need to pass emissions this year, and in the next week. :(
    P0420 Catalyst System Efficiency Below Threshold (Bank 1)
    P0546 Exhaust gas temperature sensor circult high input
    P1312 Exhaust temperature sensor malfunction
    I know one of these is my exhaust, so I need to do the resistor fix for that. But what about the others? hlpplzkthx
  2. Kokopelli
    Find someone close by with a Tactrix cable and you can turn off those cels.
  3. Mad Mallard
    Mar 15, 2005
    1,571
    4
    would that be you? ;p
    would that mean i'd be flashing into openECU?
    uhg, i hate diving nasioc for data. I keep coming up with old archived threads that predate my 04 car.
    I have randomtech up(catless) and down(hi flo cat). No cel fixes been done.
  4. Mad Mallard
    Mar 15, 2005
    1,571
    4
    Found a mechanical fix writeup for 0420 at http://www.scoobymods.com/forums/showthread.php?t=5468
    I have to clear the other two first, though. Otherwise I can't troubleshoot the 0420/0139 range depth.
    I intended to buy an AP before emissions due, but ran out of $$ and time.
    Any help or threadpointing is appreciated guys. I really don't want to be slapped with a late tag fee too.
  5. Alex
    Hmm, I'd say see if Mike (Liquidforce) could help you with it. I dont have my USB to serial cable so I cant use the laptop in the car, someone borrowed it. I passed emissions with flying colors last week, absolutely catless. Im just about to renew my tag online too.
  6. Kokopelli
    My cable is fubar'd or I would have offered in my first post. I use it to log but it loses its connection sometimes which could be bad when reflashing. I'll use it on my own car but not someone elses.
    The mechanical fix may keep the light off but it may not pass inspection. It prevented my car from entering ready mode. It needs to be in this mode for the OBDII test.
  7. Mad Mallard
    Mar 15, 2005
    1,571
    4
    well, i don't actually want to reflash with openECU, so if thats what gets done by using the cable, then I can skip that for now and try something else. Thanks, tho.
    I've got to clear these codes to pass inspection, but i'll be modding again later anyways.
  8. Kokopelli
    Its not a total flash. You would just download your current image turn off the cels and flash it back. This leaves everything else the way it was.
    I am going to the dyno day tommorow at topspeed. If strayen will bring his cable, I'll bring my laptop and we can get you hooked up.
  9. Mad Mallard
    Mar 15, 2005
    1,571
    4
    oh, didnt you have to pay to goto that?
  10. Alex
    Im sure you can show up for 15 minutes of help :)
  11. Mad Mallard
    Mar 15, 2005
    1,571
    4
    oh, they'll do that? Okay cool, not like i've never worked an event for something.
    I won't need a dyno run or anything either. Whats a good time to show?
  12. SUBY_RUE
    SUBY_RUE Member
    Dec 20, 2006
    301
    Can a obd2 scanner clear the codes and go get your inspection?
  13. Mad Mallard
    Mar 15, 2005
    1,571
    4
    i dunno, but i think when they clear codes, they clear the entire logging memory and put the ecu in a 'not ready' state that will fail emissions.
  14. Mad Mallard
    Mar 15, 2005
    1,571
    4
    thanks for the help again, liquid. And Tray. It held all the way home, i'll update when i get my emissions.
  15. mokinbird87
    mokinbird87 Active Member
    Jul 14, 2006
    1,154
    how many cats do we have in our cars again? i already lost one from getting the catless 3" helix DP, and i`m waiting on my catless up...
  16. Weapon
    Weapon 90lbs of dynamite
    Jan 29, 2005
    6,875
    1 in the up 2 in the down if you are an 02-05 rex
  17. mokinbird87
    Jul 14, 2006
    1,154
    o man, that means i`ll be completely catless when i get the sti up.... kinda scary to think about, even though i have the cobb ap... i should be able to pass emission without any cats if i have em right?
  18. jayj713
    jayj713 Member
    Feb 13, 2006
    827
    yep.
  19. knhtrdr
    knhtrdr Active Member
    Sep 6, 2004
    1,968
    gotta get ap soon myself emissions/tag commin up in a couple months fo me too.
  20. Mad Mallard
    Mar 15, 2005
    1,571
    4
    going today... will report back...
  21. Mad Mallard
    Mar 15, 2005
    1,571
    4
    Passed. Thanks again Liquid! Could you email me my old rom pls? kthx
