Flex uppipe vs Straight Uppipe
Discussion in 'Modifications & DIY how-to' started by Sparta, Jun 3, 2007.
  1. Sparta
    What is the difference? What are the Advantages of having a flex over straight or vice versa? And do brands really have a difference?
  2. WJM
    Dec 12, 2004
    5,401
    Get one with a flex in it. I HIGHLY recommend the HELIX UP, or a stock STi UP.
  3. Demo24
    Demo24 Member
    Mar 2, 2006
    846
    I'm thinking about getting a sti one.
    However I'm curious what the car would do without an egt bung?
  4. WJM
    Dec 12, 2004
    5,401
    nothing. install the resistor.
  5. Sparta
    A flex? Really? i just ordered an HKS straighty. Is there a big difference?
  6. clemsonscooby
    Dec 13, 2005
    1,536
    I have the HKS non-flex for over 40k miles with no problems. I don't believe there is a difference in performance. I don't ever here stories of them breaking on these boards. The stock pipe is not a flex on the Sti and WRX.
  7. Sparta
    sounds good. Thanks!
  8. goixiz
    goixiz Active Member
    Oct 23, 2005
    1,482
    the stock wrx and sti is flex
  9. clemsonscooby
    Dec 13, 2005
    1,536
    What? When I removed my uppipe from my 03 WRX there was no flex what so ever. Even if it was internal, i.e. behind the heatshielding, the heat shielding is one piece and wouldn't allow flex anyways.
    #9 clemsonscooby, Jun 3, 2007
  10. moose
    Feb 5, 2005
    2,969
    They're flex.
    I had a solid Perrin on without any issues.
  11. WJM
    Dec 12, 2004
    5,401
    the stock units have a small flex in them like the stock header crossover pipe does.
    I just dont recommend solids since they break when you hit stuff...when you are going offroad...like Colin McRae.
  12. Sparta
    lol, i dont plan on going offroad anytime soon. but thanks for the advisory
  13. Deke
    Jan 28, 2006
    2,694
    ooo, you're missing out :)
  14. siegelracing
    Aug 19, 2004
    1,553
    Stock is flex. All the good ones are flex. If Subaru thought you could do it without a flex, they would have left the flex out. For every 1 person that doesn't have a problem with a solid, there are 8 or 9 that have them break, crack, or leak.
    We have near 100% success with flex UP's and probably 10-20% success with solid UP's...
  15. clemsonscooby
    Dec 13, 2005
    1,536
  16. WJM
    Dec 12, 2004
    5,401
    looks like I welded that up on a windy day outside....at night time.
  17. pEd
    Mar 5, 2004
    2,460
    :rofl: Looks like my welding work.
  18. Cool_____
    Chicken shit welding FTW!
  19. KingofSiam
    KingofSiam Member
    Aug 30, 2005
    242
    Hmmm seems like a pretty strong consensus in this thread for flex uppipes.
    In a closely related issue, it seems that all coated (or otherwise heat-protective) UP's are solid.
    You guys think that stainless steel is good enough or heat wrapping/coating a good idea?
  20. WJM
    Dec 12, 2004
    5,401
    w/e....solid, flex, both, doesnt matter.
    all of them break eventually.
    I'm going to install a solid in mine.
  21. MrCoffeeATL
    MrCoffeeATL Member
    Jun 13, 2005
    761
    flex up pipe FTW, STI up pipe from ebay for cheap
  22. goixiz
    Oct 23, 2005
    1,482
    the solid ones are fine (IMHO) as long as when its installed you have no issues and dont have to stress or bend it to fit. If you have to do all that then there are stress point on the pipe nad then it will break.
    The flex joint is there so that if there are a small misalignment it wont be an issue. Even though its cast (engine) there are small misalignments and not all pipes are made the same.
