Should I switch to Denso plugs?
Discussion in 'Modifications & DIY how-to' started by ShaneSTI, Jun 7, 2007.
  1. ShaneSTI
    ShaneSTI Active Member
    Feb 18, 2005
    1,139
    I notice a lot of folks running a step colder on Denso plugs. I'm only ecutek, and tbe...for now. helps prevent detonation from what i've heard too. thanks in advance...shane.
  2. Weapon
    Weapon 90lbs of dynamite
    Jan 29, 2005
    6,875
    not needed but it wouldnt hurt
  3. ShaneSTI
    Feb 18, 2005
    1,139
    ^then i'm not going to waste 20 bucks+ for something i don't need or won't benefit me. thanks Kris.
  4. clemsonscooby
    Dec 13, 2005
    1,536
    Don't buy into the Ir or Pt plugs for sports cars. You want to change your plugs more often than not, and the purpose of the expensive plugs are to last longer. The optimal spark is still from a Cu plug, which is a lot cheapier ($2.00/plug), but they don't last as long. I personally like changing my plugs every year, it gives you insight into what your engine is doing. Meaning you can tell if you are running rich or lean, and a few other things. I always use the NGK's.
  5. Alex
    Wise words!
  6. XanRules
    XanRules Active Member
    Jun 4, 2007
    1,496
    I've never understood running "rich" or whatever.
  7. ShaneSTI
    Feb 18, 2005
    1,139
    thanks clemsonscooby. yeah i've heard there is a way you can tell if you're getting detonation...something like the white part looking a certain color. part # NGK's, and gap size? i've got 18k miles on the car, but it's an 05' so I may pick up a set of NGK's. i ran those in my SRT-4 before, and it ran a lot smoother with em'.
  8. goixiz
    goixiz Active Member
    Oct 23, 2005
    1,482
    white = lean
    black = rich
    brown = you are there
    copper is best but wears faster than IR and if you like to change them yearly and dont care if it degrades performance a tad with extended duration then CU is for you.
    I favor IR and plan to run it 35k miles
  9. clemsonscooby
    Dec 13, 2005
    1,536
    I would just search at the website of a local autoparts store, and they should have a listing of possible plugs for your car. The gap doesn't matter all that much unless you are upgraded a lot or when you pull them you can see that you are running rich or lean. Changing the gap will help with the a/f a little.
  10. goixiz
    Oct 23, 2005
    1,482
    gap about 0.030 +/- 0.002 inch
    if not heavily modded
  11. I'm Slow
    I'm Slow Member
    Apr 5, 2007
    +1
  12. Cool_____
    IR is not for meth injected guys like me. I've found I may may more power (minimal) on the IR plugs but the meth corrodes the mess out of them fast and I have to change them out more often than the CU plugs. Copper is for me. Every 10-15K miles the Subie gets new CU plugs. It's cheap insurance and plugs are so easy to change since I'm FMIC.
