Tampa Fl n00b
Discussion in 'Introduce Yourself' started by 813_05_STi, Jun 4, 2007.
  1. 813_05_STi
    813_05_STi New Member
    Just registered to check out whats going on in the ATL. I found the site off my Tuners page Scott Seigel of course. This is my 05 and mods list. I personally have done 100 percent of the wrenching, with some help from my friends. Not a shop car by any means, Love it pics and mods list below My names Bryan hello all :wavey:
    Engine:
    Garrett gt35r
    Tial 44mm Waste Gate
    Tial Blow Off Valve
    Ultimate Racing Rotated Front Mount Intercooler
    Ultimate Racing Cold Air Intake
    Ultimate Racing Up Pipe Ceramic Coated, DEI Black Heat Wrapped
    Ultimate Racing Down Pipe Ceramic Coated, DEI Black Heat Wrapped
    Gruppe-S Header Jett Hot Coated, DEI Black Heat Wrapped
    Top Speed Blow Through Maf Housing
    Perrin Fuel Rails
    Power Enterprise 850cc Injectors
    TGV'S Ported and Bench Flowed to 440crm
    Hondata Intake Manifold Gasket
    NRG Dual Catch Cans
    NGK Iridium 1 step colder plugs
    PWR Radiator
    Crucial Racing Radiator Cap
    Crucial Racing 160% Thermostat
    Samco Radiator Hoses
    Watter Wetter
    Crucial Racing Copper Gaskets, Header,Up,Exhaust
    AGP Copper Garrett 4bolt Flange Gasket
    Trans:
    ACT 2500 Pressure Plate
    ACT 6 Pad Race Disc Unsprung
    ACT ProLite Flywheel
    ACT Throw Out Bearing
    ACT Pilot Breaing
    Stainless Steel Clutch Line
    Brakes:
    Hawk HPS Pads
    Stainless Steel Brake Lines
    Motul RBF600
    Suspension:
    Race Comp Engineering Springs
    Hardened Strut Mounts
    Falken rt615
    Managment:
    Ecutec
    Apexi ACVR
    Apexi Turbo Timer
    Walboro 255 Fuel Pump
    Summit Battery Relocation Kit, Vented, NHRA Approved
    Exterior:
    Spec C Lip
    Jdm Cold Air Induction
    Cleared Headlights
    De-Badged Trunk
    Interior:
    Defi BF Imperial Boost
    Defi BF Inperial Pyro
    Lotek Pod
    Valentine 1
    Valentine 1 Phantom Display
  2. Deke
    Love the setup.
    Welcome to the boards!
  3. BelvnAWD
    Thats two hot Aspen Whites in the less than a week! Welcome!
  4. pEd
    damn nice setup you got there Bryan.
    So you've got a 35r on a stock block?
    Can I ask how long you've had the turbo in on it?
  5. miloman
    Very clean.
    Welcome to WRXatlanta.
  6. MarkM2016GTI
    MarkM2016GTI Supporting Member
    Nice Set-Up Bryan...Welcome to the forums...Tampa is a great area...
    Mark
  7. I'm Slow
    I'm Slow Member
    welcome
