AutoX Wheel and Tire setup
Discussion in 'Meetups & Events' started by SubiNoobi, Nov 5, 2007.
  1. SubiNoobi
    SubiNoobi Supporting Member
    After running two Autocrosses with my 205-55-16 (440 treadwear) tires I wanted a new setup.
    This is what I am going with:
    16x7 RS wheels and Hankook Ventus rs2 Z212 (why are some tire names obnoxiously long?) size 225-45-16.
    This upgrade will accomplish several things:
    1. Stickier Tires
    2. Wider contact patch
    3. This will make my overall diameter about 1" less. I know this will effectively lower my gear ratios and lower the car about .5".
    I KNOW this will mess with the odometer and speedometer, however these tires will be for AutoX ONLY! After I wear them in a little, of course:)
    So my question is this:
    I want my car in STS, and I read through the SCCA rulebook for AutoX classing. I couldn't find any restrictions on tire size other than treadwidth. Is this going to be legal for STS class? And will it be beneficial for AutoX?
  2. RamblinWRX
    RamblinWRX Member
    I thought you couldn't run r-comp tires in street tire classes.
    nm that's just the z214.
  3. WJM
    7.5" rim width is the limit for STS
    8 for STX
    No limit on rims for STU.
    Tyre:
    225 STS
    245 STX
    245 for AWD in STU
    275 for FWD/RWD in STU
    You are good for STS. The 1 inch diameter change will not be a large enough change to worry about speedo readings for street use.
  4. SubiNoobi
    Nevermind, found my own answer.
