axis or hawk hps?
Discussion in 'Modifications & DIY how-to' started by scoobaru, Jan 14, 2008.
  1. scoobaru
    scoobaru Active Member
    Jul 9, 2007
    977
    I need new pads front and rear....and im looking at two sets.
    The axis ultimates, or the Hawk HPS.
    Which will better suit me for daily driving? Im on a budget right now, so the axis's price is appealing. But if they are total crap then ill squeeze in the hawks.
    Any help is appreciated!
    either hawk or carbotechs.....
    never heard anything REALLY good about axis...
  3. SonicBoom
    Nov 1, 2004
    2,265
    Bump for answers.. I'm looking to replace my pads, even though they have over half life left... I needs pads that dust A LOT less...
  4. blindfold
    blindfold Active Member
    Aug 29, 2006
    1,596
    running hawk HPS on the street, very mild amount of dust. Keep this pad for STREET ONLY.
  5. JJang12
    Aug 17, 2004
    803
    If you are okay with brake dusts, go with axxis ultimate.
  6. scoobaru
    Jul 9, 2007
    977
    how much do the carbotechs run? I found a deal on some hawk hps so i might just order those. Also, i have slotted rotors, can i have them turned/resurfed? where would i have that done?
  7. Strayen
    Strayen Active Member
    Oct 17, 2006
    1,041
    Yea go with HPS. For street use, they are great! There is some dust but not bad at all and they haven't squeaked at me once.
  8. blindfold
    Aug 29, 2006
    1,596
    slotted/drilled rotors cannot be turned.
  9. Kokopelli
    I had my slotted rotors turned.
  10. blindfold
    Aug 29, 2006
    1,596
    really, do you still have slots afterwards?
  11. 1984
    1984 Member
    Apr 28, 2005
    123
    It's only a light sanding of the surface to get the old pad material off of the rotor...If you were to sand enough material off a set of slotted rotors to where they were not slotted anymore, the rotor would definately be thinner than what I would consider to be safe enough to continue using.
  12. Eta1405
    Eta1405 Member
    Jul 29, 2004
    47
    Werd. I ran axxis ultimates and there was no reason to ever clean my wheels. It would only take one 20 minute drive after a car wash and the fronts would be coated with dust again.
  13. josh booth
    josh booth Active Member
    Jun 23, 2006
    1,549
    I am running hawk HPS.... Very nice pads for the street.
  14. blindsideair
    blindsideair Member
    Oct 15, 2006
    18
    I am about to get a set of HPS due to all the great reviews I have read about them. Although,,,,,,,,,,, I have EBC Green Stuff pads on my autox/street miata and they are absolutely amazing brake pads with little dust (tons and tons and tons of bite and just when you think they are to hot to stop even a barbie jeep, there is more bite!). The only downside is that they are Lime Green. If they were black, I would be buying EBC's instead of HPS..
  15. AXLEJOHNSON
    AXLEJOHNSON Member
    Feb 14, 2007
    460
    I found the HPS front and rear on Amazon for about 190.00 shipped, anyone know of any better deals for a STi?
  16. calmnothing
    calmnothing Shlimp Flied Lice
    May 10, 2005
    1,691
    Honestly I hate the hawks. You got most of the braking power just by barely touching the pedal. It's hard to keep your braking linear and smooth. You'll find that there's a lot of head bobbing because you tap the brake pedal and your car comes to a screeching halt. The carbotechs have been a lot more graceful in delivery.
  17. scoobaru
    Jul 9, 2007
    977
  18. integroid
    Hawks, Porterfield, or Carbotech.
  19. AXLEJOHNSON
    AXLEJOHNSON Member
    Feb 14, 2007
    460
    Thanks, scoobaru, just ordered them.
