Storing a Shortblock?
Discussion in 'Modifications & DIY how-to' started by integroid, Mar 26, 2008.
  1. integroid
    Just curious if anyone has any tips on how to store a short block? Anything I should lube? Should I wrap the block in a plastic bag or anything? Thanks for your help.
  2. Kokopelli
    I have seen people use a light coat of grease (white lithium) on the cylinder walls and crank snout and to keep them from rusting.
    How long are you planning on storing it?
  3. integroid
    Until I cam afford to have someone install it for me;) Probably at least a few months maybe up to a year?
  4. Kokopelli
    I know someone who can install it and he takes old parts as part of the payment. You may not need to save up as much as you think.
  5. I would cover it with wd-40 and then wrap in trash bag and suck the air out with end of vacuum hose.Also I would put one of those packages of damp-rid in the bottom of the bag.(usu. at grocery store).
  6. integroid
    Funny, I think I knwo the same person:)
    I honestly am still debating if I should keep the old short block for a rainy day. It just seems like short block prices keep going up and up I might as well just save it or slowly build it.
  7. integroid
    That was exactly what I was thinking of doing.
    Thanks for all the advice so far.
  8. WJM
    WD40 will only last a few weeks. I found this out the hard way.
    HEAVY grease and LOTS of it on the cyl walls, both ends of the crank and any other surface that is steel, then wrap it REALLY good with packaging wrap.
    Store is in a DRY PLACE. Aka NOT a garage floor. Stick it in your bedroom closet. Thats best.
    I have about 7 shortblocks on my garage floor...they are all ruined now due to the amount of moisture there. All of them rusted.
    I'm not a happy person with that situation.
  9. WRXCoupe
    WRXCoupe Active Member
    Wow I learnded something new today! Really good info, gotta love it!
  10. integroid
    What kind of heavy grease are we talking about here?
  11. integroid
    What kind of heavy grease are we talking about here? Spray type or a tub of grease?
  12. WJM
    tub of grease...like heavy wheel bearing grease.
  13. integroid
    Do you think heavy grease like that will harm the shortblock once it is put together and fired up? More so thinking about the cylinder walls.
  14. WJM
    No. Before install you clean it all off. It may smoke some in the first few miles if the grease gets down into the rings. However, you want to protect the block from rust. I'll deal with some smoke for a few minutes vs the block rusting and needing work later on that will cost money.
    I used to store lots of blocks like this.
  15. riddlinkidd66
    riddlinkidd66 Member
    where to get greese like this? autozone?
  16. integroid
    Yup, autozone, advance, walmart, etc...
  17. Gawrx
    Gawrx Member
    Gun oil has excellent rust prevention additives. Another good rust preventer oil is Marvel Air Tool oil.
  18. dpbgst13
    dpbgst13 Member
  19. UpSideDownDesi
    UpSideDownDesi Active Member
    best place to store it........under the hood. :D
  20. Mr. Kidd
    Mr. Kidd Member
    Wipe the cylinders down with oil and you should have used assembly lube on the rod bearings an crank.
    That will keep everything fresh for awhile.
    Wrap it with shrink Wrap TIGHT and you should be good for 60-90 days
