just bought an 04 wrx need help
Discussion in 'Introduce Yourself' started by tmr4479, Apr 17, 2008.
  1. tmr4479
    tmr4479 New Member
    I buy and rebuild cars. I just bought an 04 hit in the right front. I cant get this thing to start, checked the timing belt its not broken has compression has fuel, and spark. Any tips yall can give me? if not anyone in atlanta i can take this car too? I really wanna get it running before i repair it. It also had a wrxatlanta.com sticker under the mirror so I guess it belonged to someone on this board. Thanks for any tip yall can give me.
  2. Sparta
    is the airbox/maf destroyed? Also check the intercooler piping
  3. RoMe
    RoMe Active Member
    Take it to KingWrex (Steven) at classic Subaru in Atl he will get it right
  4. JJang12
    Maybe it has Cobb's antitheft map as basemap?
  5. GTscoob
    Is the starter working? Is it spinning the motor? Are all of the coils down on the spark plugs? Does it start and then stall? Its hard to diagnose your problem when the only info we're working off of is that it wont start.
  6. tmr4479
    tmr4479 New Member
    yeah the air box is trashed, installed a new mass air, all the coils are on the plugs. yeah it does kinda start for a second then die and not start again. I know nothing about thses cars, just bought it cheap and heard they are fun to drive.
  7. tmr4479
    tmr4479 New Member
    also if any of yall have any front end parts let me know, I need a hood bumper cover right fender grill upper tie bar air box ect..
  8. Sparta
    I am betting that its not reading the appropriate air assuming everything else is fine. PM Kingwrex, maybe you can get him to come to you and diagnose it
  9. Alex
    What year is it?
  10. Matt
    title says 04 :)
  11. GTscoob
    Check for any massive pre-throttlebody vacuum leaks. I had one right at the turbo inlet and it caused my car to stall occasionally when cranking.
  12. ptc075
    ptc075 Member
    Double check you installed the new MAF correctly & not backwards. It's held in by 2 small screws which are slightly offset. With a little effort it's possible to install it 180 degrees from where it's supposed to be. Not that I would know.... ;P
    With the MAF backwards, the car will start, then get a negative airflow reading (I assume) & immediately shut off again. Sounds similar to your problem.
    -Chris!
