help with 60t check up
Discussion in 'Introduce Yourself' started by amjp23, May 9, 2008.
  1. amjp23
    amjp23 New Member
    just wanted to know if you guys know a cheap place for a 60,000 mile check up.went to one place was charging me 930 which i think is too much,i have 2004 sti thanks.
  2. FACE
    You should talk to Kingwrex and he will take care of you!
  3. schneid
    schneid Member
    cant remember what 60k service includes off the top of my head, but after giving SOG a few hundred for basically a new set of windshield wipers for my 30k service, Im going to do this one myself
  4. pEd
    As far as I remember, it's basically a change of all fluids, and a timing belt change.
    You might as well replace the water pump while you're in there as well.
    Here's a schedule--> Subaru Maint Schedule
  5. Davidwrx
    Davidwrx Member
    Unless the 04 STi is different than my '02, here is what was in my '02 list:
    Oil, filter
    transmission fluid
    Brake fluid
    change coolant
    air filter
    fuel filter (maybe newer cars don't have this)
    spark plugs
    PCV (not on list, but I did this)
    Power steering (not on list but I did)
    wiper inserts (if necessary)
    rear diff fluid
    rotate / balance tires
    No mention of the timing belt until 90 or 105K.
  6. nsvwrx
    i have SOG 400$ for ALOT of things. including sparkplugs tranny flush, oil change, rear diff
  7. schneid
    schneid Member
    Ive read that there is a filter that is inside the oil feed line going to the turbo and that some say it is a good idea to remove. e.g. the filter can slowly become clogged and cause the turbo to lose its oil supply = turbo failure. anyone ever removed or cleaned this little guy? check out forcedperformance's website, they have a lil tab about it
  8. techlord
    I looked for that filter the last time I replaced my turbo and it did not have one...Mine is an 03 tho
  9. schneid
    schneid Member
  10. pEd
    I pulled the ones out of my car during my turbo swap.
  11. amjp23
    amjp23 New Member
    need a place for 60t check up
    who is kingrex? how do i get a hold of him, so no suggestions on a place in ga that will do it for me besides dealership.
