clutch toasted
Discussion in 'Modifications & DIY how-to' started by para83, Sep 1, 2008.
  1. para83
    para83 Member
    clutch is about done on my 06 wrx and i need a replacement. anybody got any ideas as to which is the best replacement for the clutch i hear mixed reviews on everything. also what are all the components that need to be replaced with the clutch
  2. techlord
    well I got the act street racing clutch kit (clutch disk/pressure plate/TO bearing) and have had no issues on my quest for more power.
    I would consider resurfacing/replacing the flywheel while you are in there.
  3. slowwrx
    What are your Horse Power Goals?
  4. para83
    para83 Member
    at the most a little above sti standards i want to squeeze as much as i can without stressing the transmission too much
