knotchy gears
Discussion in 'Modifications & DIY how-to' started by mokinbird87, Sep 8, 2008.
  1. mokinbird87
    mokinbird87 Active Member
    my gears are feeling a lot more knotchy then usual, especially my third gear... i do have 114K on it, so do you guys think something big is coming up? (i just replaced my radiator and the clutch so i dont want to hate my car again hehe)
  2. crashtke
    Last time you changed fluid?
  3. '05limited
    '05limited Member
    ^ +1, try some subaru extra s gear oil first... see if that doesn't clear it up.
  4. Cool_____
    I've not been impressed with the Subaru Extra S. Motul Gear 300 FTW!
  5. WJM
    Extra-S FTW.
  6. mmtasty
    mmtasty Active Member
    extra S should do the trick. I have one gallon left if you'd like it.
  7. Cool_____
    I don't understand extra S. I have it in my 2007 sti trans and it will randomly grind 4th. I flushed it and put more extra S in it. Still a very random grind (like 3 a month). Flushed that out installed Motul and 3 months I've had ZERO grinds and trust me I've tried to make it grind.
  8. mmtasty
    that's because it's magical. nobody knows what it is... WJM said it was created by unicorns that needed something for their slip-n-slide to candy land. :squint:
  9. WJM
    Other 07-08 trans are getting random 4th grinds.
    Drive it harder and it doesnt grind.
  10. Cool_____
    It NEVER grinds under power. It's always the in traffic easy slow shift that grinds and is almost ALWAYS in the 3500-4000 rpm shift area. Oh well Motul seems to solve it....or at least 'mask' it.
  11. WJM
    Yep, thats the complaint we get.
  12. Cool_____
    Interesting....oh well if Subaru does anything I'm out of luck as that transmission didn't come in my car from the factory :(
  13. WJM
    Yep...
  14. adidasboy1186
    adidasboy1186 Member
    deff a fluid change
  15. crashtke
    Wow, just looked at the price of that Motul 300...$17 a quart....kinda high!
  16. Caffeinated
    Caffeinated Member
    I was getting the random grind thing going into 4th every once in a while. I switched to Amsoil Severe Gear 75w-90 and the trans now shifts like buttah.
  17. Cool_____
    Yeah it is but as they say....gotta pay to play ;) The fact I can get it easily works for me since the Subaru dealership will not buy Extra S and split it and I'm not buying 5 gallons of it.
  18. dontcallitarex
    dontcallitarex Active Member
    My transmission is notchy too, but I chalk that up to my kartboy. I changed my fluid with new Extra S at around 32000 miles. I didn't notice that dramatic of a difference. Personally I'm thinking of trying the Motul gear oil next time. I'm interested to see how it feels.
    Other than that, I get locked out of reverse quite a bit, but according to manual and every other subaru owner I've talked to its normal.
  19. crashtke
    Not to sidetrack too much, but if you get locked out of reverse, try putting some gentle pressure on the gate and let the clutch out slightly until it goes into gear. That is what you HAVE to do some times on the 18 wheelers and I tried it on a couple manual cars I drive and it works wonders on them too :)
  20. Matt
    that and you can put it in 1st and then it should slide into reverse with no issue. :)
  21. crashtke
    Correct since they are on the same shaft or syncro or something fun like that.
  22. mokinbird87
    also, i put it in 3rd, roll forward a little, and then boom, straight into reverse. works like magic every time. it's become such a habit, i do it anyways when i go into reverse.
