white smoke
Discussion in 'Modifications & DIY how-to' started by johnswrx, Sep 25, 2008.
  1. johnswrx
    johnswrx Member
    Ok so my car has been putting out some white smoke at idle for a few months. I had it at topspeed for a new block and rebuilt heads and it has been doing it since.(not trying to bad mouth topspeed or blame them they do great work) It does it when im stopped at red lights and such not when actually driving down the road. It seems to have gotten worse as time goes bye. Any clue what this could be?
  2. WJM
    Do a compression and leakdown.
    If its a blueish white its oil smoke.
    if its WHITE WHITE its coolant.
    If its a light gray-ish color its normal for some cars during certain times of the year and dont worry about it.
  3. Cool_____
    Sniff the smoke....does it smell Sweet or gasolineish?
  4. johnswrx
    johnswrx Member
    yeah its white white and has a burning smell to it
  5. nsvwrx
    odd white white is usually coolant and its sweet...
  6. Cool_____
    It's coolant. Coolant seals on the turbo may be going out.
  7. WJM
    Much truth...
    However, you should be able to smell burned coolant in the exhaust.
    BUT...if its a super small amount, it may not smell but indeed smoke.
  8. johnswrx
    johnswrx Member
    so what happens if the turbo seals are going out? am i going to have to buy a new turbo?
  9. Cool_____
    No you get it rebuilt if you can. Don't you have a rotated t3/t04s?
  10. johnswrx
    johnswrx Member
    yeah its a t3/t04s. how much do you think it would cost to rebuild it
  11. Cool_____
    Probably 4-500.
  12. siegelracing
    If it mostly smokes at idle, it is most likely turbo seals...
    Siegel
  13. Tray@topspeed
    Tray@topspeed Member
    Jonathan, Give me a call. The turbo is bad. Need to upgrade. Call me up.
    678-297-7770
    Thanks!
    Tray M
  14. Afande
    Afande Member
    If it's white smoke then it's likely coolant but the t3/t04s turbos are normally oil cooled only....so is this one oil / water cooled?
  15. Cool_____
    Good point there Afande.
  16. siegelracing
    It's blueish smoke. It's just oil.
    Siegel
  17. Kokopelli
    Do the compression check before you buy a new turbo.
  18. Doug@DBW Motorsports
    We pulled the uppipe and there was no oil in the uppipe. Yet downpipe is covered in oil.
  19. Kokopelli
    or check that ;)
    I had a turbo rebuilt by Precision for 200. Give them a call. They are very reasonable and turn it around quickly.
