CAn i fit this size tire?
Discussion in 'Modifications & DIY how-to' started by bigb996, Aug 7, 2005.
  1. bigb996
    Can i fit 235/45/17 tires on my 17x7 wheels? I had them on my last car but i dont remember what size the rims were. Or should i just do 225's? They cost almost the exact same i think the 235s might be a few dollars cheaper.
  2. jt money
    i have 225 on mine with no problems. ive heard of people running 235 but dont know about rubbing after you lower the car.
  3. miloman
    im running 235 and i would be pretty close to rubbing if not for the camber and the stiff suspension
  4. bigb996
    yea i thought u had the 235 milo.....so 225 would prolly be a better idea? I have 225 now that came on the wheels but i dont wanna scrub when i get a drop.
  5. miloman
    u might be able to fit 235... i dunno... but with 225 u should have no problems
  6. BelvnAWD
    225 is not a problem at all, unless you really slam the car...
  7. bigb996
    i am most likly getting tein s techs i know evyerone has them but i had them on my last car and was VERY pleased. I also dont have NEAR the money to pay for coilovers. Thanks guys..........
    BTW are hankooks alright?
    im looking at them on www.edgeracing.com i can get 4 225/45/17s for 308 shipped
  8. FullTimeStudent
    FullTimeStudent New Member
    225/45 should be good for 17x7 wheel.... I have the same size tire on 17x7.5 Rotas and they fit perfectly on my wagon with Prodrive springs. My previous whiteline springs were waaay too low for the Pirellis I have now(225/45). Tein S tech? ...perhaps you'll clear barely if you have a sedan......
  9. rolling_trip
    rolling_trip Active Member
    i'd stay away from them. i know the price is tempting, but my buddy has told me some horror stories about them. he worked at goodyear tire co and saw a bunch of tire seperation in them, mainly performance type
  10. SonicBoom
    Just my opinion, but I think 235 is to wide for a 7" rim. I have 225's on a 7" an there's a little bulge in the sidewall, so I'd imagine 235 would be worse, causing uneven wear, scrubing...etc... I'd stick with 225's....
  11. monk
    totally agree, i think they are kumho's "off" brand... i've heard nothing but crap about them.
    kumho's are the "cheapest" performance tire i would go with, and make sure you get the 712 sidewalls if you get them.
  12. miloman
    i agree with you chris... i have 235 on my 7.5 inch rims and theres still a bulge
  13. bigb996
    yea i htink 225 sounds like a good idea. Anyone know a good place to get a good deal on tires? I am trying to spend under 400 installed if possible.
  14. SonicBoom
    I think your looking at closer to $500. Most tires in that size are around $100-$125 each, then install/balance. I recommend discount tire. I have Kuhmo 711's and there pretty decent.
  15. bigb996
    yea i can do the 711s for 100 a tire installed at kauffman.
  16. miloman
    the 712s and ASXs offer much more grip than the 711s... dont remember how much more expensive they are though
  17. married05gt
    married05gt starting over
  18. psychobooe
    psychobooe New Member
    Just a word to the wise, if you're going to get 235s, make sure that you get 235/40 17s. I bought a set of wheels and tires off of a guy and they have 235/45 17s on them and was getting some rub until I got the inside lip of my rear fender shaved down. The 235/45 is almost a half inch taller in overall height than the stock wheel/tire combo. The 235/40 is about a half inch shorter than stock. The 235 tires will fit fine on a sedan, just make sure that you get the 235/40s.
