few questions
Discussion in 'Modifications & DIY how-to' started by turbowagon, Oct 17, 2008.
  1. turbowagon
    turbowagon New Member
    car- 03 legacy wagon
    question- how hard would it be to turbo the stock motor? Would i be able to use stock turbo, dp, and top mount from an sti/wrx?
    Or would it be easier to buy a turbo motor swap?
    I want to make about 250 to the wheels. Which direction should i go. and also the car is an auto slush box.
  2. nsvwrx
    Buy a turbo motor and swap.
  3. dontcallitarex
    dontcallitarex Active Member
    Yeah, that.
    Look for a stock 2.5L wrx motor and turbo. With a good tune and the right parts 250whp isn't impossible at all.
  4. XanRules
    XanRules Active Member
    this
  5. calmnothing
    calmnothing Shlimp Flied Lice Supporting Member
    Or you can buy a turbokit off rs25.com forums and do 5lbs of boost to get you there. There are kits for <$1500
  6. turbowagon
    how well do the stock motors hold up to boost?
    how different impreza's chassis from legacy's?
  7. nsvwrx
    They dont hold up very well.... as far as i know at least
    Its the consensus that you buy a new turbo motor.
  8. Berzerklo
    Berzerklo Active Member
    I don't know how many people have put a turbo on an N/A motor because there is such a ready supply of turbo motors. They really are completely different internals and with a turbo motor, plus Engine Management is all already done for you!
    If you want to save a leetle bit of $$ you could look for a WRX 2.0 and put a VF 39 on it from an STi. With all the right add ons (Full exhaust and a tune) 250 whp should not be hard at all.
  9. turbowagon
    ok next question, where can i buy a wrx motor from. im not trying to spend $4.5 for a sti motor.
  10. WRXCoupe
    WRXCoupe Active Member
    This may be overkill but it may actually turn out to be cheaper. You might want to trade the Legacy auto for a used WRX wagon, Sedan or even an Sti. If you start off with a turbo/5sp platform your options will be vast and actually allot cheaper.
  11. turbowagon
    i thought about that too, i just dont really care much about the looks of the impreza wagon. im loving the legacy. i think i might try see if i can find a jdm legacy gt wiring harness. and use a wrx motor and just upgrade the turbo and tmic.
  12. seanwrxwagon
    seanwrxwagon Member
    If you like the legacy I say stick with it. Just be prepared for a few more headaches and some additional costs. You could go with a JDM 2.0 and hit your goals pretty easily. If you were to find a 2.5 motor it would be easier still.
  13. nicad
    hit up jhot in augusta. lots of cheap twin turbo motors from legacys
  14. calmnothing
    What's your budget for all this?
  15. Cool_____
    You need to upgrade the tranny as well ;)
  16. calmnothing
  17. turbowagon
    i dont really have a budget, i am just trying to avoid paying almost 5grand for a motor and tranny. i am going to do a little more searching/research before i do anything.
  18. XanRules
    we know you're a big fan of those :pssh:
  19. crashtke
    You could always get a sti short block and build it.
  20. WRXCoupe
    If your looking to avoid paying five grand for a motor and tranny you may not want to do a motor and tranny. :rofl:
