Just got my Primative Racing Skid Plate
Discussion in 'Modifications & DIY how-to' started by billys06sti, Oct 31, 2008.
  1. billys06sti
    billys06sti New Member
    Oct 20, 2008
    13
    Earlier this year when I did my first oil change I found out that the previous owner had gotten rid of the plastic undertray. I decided that I was going to get a metal undertray. I finally decided to go with a 3/16 inch primative skid plate. It is pretty nice I thought I would share some pictures.
  2. 2thAche
    2thAche Member
    Sep 13, 2007
    302
    How much does it weigh?
  3. billys06sti
    Oct 20, 2008
    13
    It weights about 17 pounds. But this one is the 3/16 inch skid plate. Primative racing sells 1/8" skid plate that is the same style I think it is about 10 pounds.
  4. FTZ
    Oct 10, 2004
    4,572
  5. Berzerklo
    Berzerklo Active Member
    May 21, 2007
    961
    that is sexy
  6. 07Ltd#767
    Jun 8, 2008
    1,817
    very nice...make sure to post some pictures up after install. We did my sways this weekend and when we finished Jeb and I had two extra bolts left over...they go on the plastic tray, we just had no idea how to put them back on. Hope they weren't that important....and at least there are about 40 other screws holding it in place.
  7. billys06sti
    Oct 20, 2008
    13
    Here are some pictures installed.
  8. dontcallitarex
    dontcallitarex Active Member
    Sep 23, 2007
    1,443
    Nice!
    Does the car feel any different on the highway? I've been told that the undertray is an important aerodynamic element of the car.
  9. billys06sti
    Oct 20, 2008
    13
    I do not feel difference on the highway. But I did notice a less engine noise at idle.
  10. Cool_____
    I wish that it had a compartment/flapper to make oil changes a breeze.
  11. billys06sti
    Oct 20, 2008
    13
    They will cut a oil filter access hole for a charge. I figure if I need that I can do that myself down the road.
  12. Cool_____
    I know but you will still drip oil all over the underside.
  13. Bug-Rex
    Bug-Rex Active Member
    Oct 13, 2008
    902
    Was the install easy?
  14. seanwrxwagon
    seanwrxwagon Member
    Apr 13, 2008
    263
    You could relocate the oil filter to a more accessable place and do a quick disconnect to drain the oil through the plate.
  15. billys06sti
    Oct 20, 2008
    13
    It was pretty easy to install I could not get the middle bolt in because my subframe is bent in the front. It took me 10 min by myself. I hardest thing was holding up the plate by myself.
