Started out looking like this when i got it. Now... Drivetrain: Cobb Version 1 AccessPort with Scott Siegel 93 oct tune at Topspeed DeadBolt MonsterPort TD-04 Turbo Ceramic Coated Port & Polish (Gasket Match) Exhaust Manifolds Ceramic Coated Injen Crossover Pipe Ceramic Coated APS Up-Pipe Ceramic Coated & Wrapped APS 3” downpipe inlet Ceramic Coated Borla Hush cat-back Perrin Turbo Inlet Hose TurboXS Bar & Plate Intercooler STI Hood Scoop NGK BKR7EIX-11 Iridium Spark Plugs RA Version 6 Gearset w/Dual Cone Sync by RalliSpec Excede Stage I Clutch ACT Streetlite Flywheel Walbro GSS-342 Fuel Pump Suspension: Whiteline Group 4 coilovers with Grp-N top hats MRT 20mm Front Sway Bar MRT 20-24mm Adjustable Rear Sway Bar Whiteline Front & Rear Sway Bar End Links Subaru Heavy Duty Rear Sway Bar Mounts GTSpec Anti-Lift Kit Ingalls Camber Bolts in Rear Struts Brakes & Chassis: PowerSlot Cryo Brake Disks Front & Rear Ferodo DS2500 Brake Pads Front & Rear H6 Rear Brake Disk Upgrade Perrin Rear Differential/Subframe Lockdown System Whiteline Rear Strut Tower Brace Turn in Concepts Fender Cowl Braces “H Brace” Under Front End K&N Panel Filter Braided Steel Brake & Clutch Lines Bushing Upgrades in Steering Rack, Rear Lateral Links, Shifter, & Tranny Mount and the dyno graph...
NICE! White is the BEST color by far... Good to see you're still around too. On a side note, did you ever get a supermoto? Hey Bobby (because I'm sure you'll look at this white wagon porn), what happened to Scotty's and/or his car? Steven is who I bought it from.
