p0031 CEL
Discussion in 'Modifications & DIY how-to' started by jayjaysti, Feb 9, 2009.
  1. jayjaysti
    jayjaysti Member
    what can i do?
  2. pEd
    That's related to the front O2 sensor.
    Have you done any mods lately? Pulled the exhaust manifold?
    I'd check the wiring at both the sensor end and the connector end in the engine bay.
  3. siegelracing
    Generally you have to replace the front o2 sensor...
    Siegel
  4. jayjaysti
    jayjaysti Member
    dam i just replace my clutch this car is killing me :( anyone has a cheap one?
  5. Mike@TTR
    Heard bad thing about cheap ones....don't want to go cheap on the front o2 sensor. That is what the ECU uses to control fueling. WJM seems to think that the aftermarket ones are not calibrated correctly for the Subarus. A OEM one would probably be best.
  6. jayjaysti
    jayjaysti Member
    how much do they go 4
  7. Bug-Rex
    Bug-Rex Active Member
    Don't mod your car, and it won't kill you. :)
    Thats my opinion though, and is kind of hard to tell a wrx/sti owner that... :rofl:
  8. pEd
    did you pull the motor to change the clutch?
    If so, I bet the sensor or the wiring got smashed when the motor was coming up and out.
    It looks expensive.... Clickity Clack
  9. techlord
    ^^yep that is the best you are going to find.
  10. siegelracing
    We sell Subaru OEM sensors for $172 or something...
    Siegel
