Offset for wheels
Discussion in 'Modifications & DIY how-to' started by SFGIANT, Aug 20, 2005.
  1. SFGIANT
    SFGIANT New Member
    I'm looking at a wheel that I like, but they only make it with a 35 or 40 offset. I'm pretty sure that 35 won't work ( I have an 05 wrx), but I'm not sure about the 40. Is anyone running wheels with an offset of 40?
  2. WRX-WRC
    what width is the wheel? with a 40mm offset you should probably be running a 8.5 wide wheel.
  3. SFGIANT
    SFGIANT New Member
    The wheel is a 16x7...
  4. Alex
    Maybe an offset of high 40s or low 50s.
  5. WRX-WRC
    i do not sugest getting a 7 inch wide wheels with anything less than like 48-50mm offset
  6. Alex
    Exactly.
  7. 5spdfrk
    5spdfrk Active Member
    The optimum offset for our subarus is usually a +48. From what I have gathered from other sites, you do not want to go more than +/-5 in either direction. So no less than a +43 and no more than a +53.
  8. plokivos
    plokivos Member
    i agree.
