No AC - can anyone advise?
Discussion in 'Modifications & DIY how-to' started by Cino, Apr 3, 2009.
  1. Cino
    Cino New Member
    Mar 27, 2009
    5
    Can anyone help me w/ an AC problem? Mine has stopped working.
    It was working fine, then one day I turned it on and didn't feel or hear the compressor kick in. After that, nothing but ambient temperature air coming out of the vents. Tried turning it off and on, playing w/ the switch, etc., nothing. The compressor just doesn't kick in.
    Is there a solinoid or something that I can check or replace? I am hoping that this is not a compressor issue.
  2. FTZ
    Oct 10, 2004
    4,572
    What year is your car? Could just need a recharge.
  3. techlord
    Jan 6, 2006
    2,385
    probably just needs to be charged as 420 says, it wont kick on if low.
  4. Davidwrx
    Davidwrx Member
    Apr 11, 2007
    375
    I have just fixed mine for the same symptoms. Dealer said I had a leak in the high pressure hose. Bought a used one here and had recharged at a shop near my house. Try the recharge and if it leaks out, may want to take it somewhere to find the leak / diagnose.
  5. midnight_rider
    Mar 8, 2007
    289
    Like Davidwrx said above me you more than likely have a leak somewhere in your system. Before you pay to have it recharged, you should have a technician look for a leak that way you dont recharge it and have to do it all over again once it seeps out again.
    #5 midnight_rider, Apr 4, 2009
  6. Sparta
    Autozone has a leak finder kit for like $20. The dealership charges like $90 to have checked out.
  7. Cino
    Cino New Member
    Mar 27, 2009
    5
    Thanks. I would not have thought that a low charge would result in the compressor not kicking in. There was a time when you checked for a low charge by running the compressor and looking for bubbles in the view glass.
  8. Davidwrx
    Davidwrx Member
    Apr 11, 2007
    375
    There is a low pressure switch under the washer fluid tank that stops the compresser when it is low. Helps protect the system.
