Slipping Clutch
Discussion in 'Modifications & DIY how-to' started by lieutenant dan, Jun 13, 2009.
  1. lieutenant dan
    lieutenant dan New Member
    Apr 27, 2009
    17
    my clutch is starting to slip but it's not too bad. i can still drive it but i want to replace it befor it goes out. what are some good clutches to look at?
  2. Jake
    Any aftermarket "stage 1" or stock/oe replacement clutch. You do not need anything stronger than that unless you wanna replace your tranny soon. I recommend the exedy stage 1/oe replacement clutch.
  3. ZenMotors
    ZenMotors Member
    Mar 2, 2009
    601
    Go with an act street disc. It's a good clutch that will last a long time. Comfortable pedal pressure, and won't break the bank. If you are wanting a deal on the clutch & install. I can provide you a price hard to beat!!!
    Let me know!
    Take care!
  4. Jake
    What he said. They hooked up dana when he needed a new clutch too
  5. lieutenant dan
    Apr 27, 2009
    17
    you don't think a stage 2+ will work and not hurt anything?
  6. Jake
    Not worth the risk or the extra money. Your basically stock.
  7. Trancetto
    Jul 9, 2008
    1,321
    No need for stage 2. Its like putting a nos kit on your car that you will never use.
  8. lieutenant dan
    Apr 27, 2009
    17
    well i just heard that the stage 2+ spec clutch is good for daily driving as well as hard driving
  9. Jake
    I haven't heard anything positive about spec clutches on subarus. King had a hard time installing one on integroids car I think
  10. kingwrex
    Feb 12, 2006
    1,195
    11
    Yea, i would stay away from spec clutches. Go with the ACT clutch and be done with it.
  11. integroid
    Go with the ACT clutch. I have never had a problem with their clutches in the past 15 years. THis is coming from someone that has a SPEC cutch in his car now.
