i have an 03 wrx with many mods but my main problem is my piping shortly after the turbo...i have a vf34 with fmic and i keep blowing the pipe off...the main reason is is because the pipe doesnt quite fit...where can i find and or have another pipe made and have the rest of my pipes lipped??
You need a bead roller or get someone to weld a bead. Have you tried spraying hair spray inside the silicone coupler before installing?
nope im using the good clamps already...im pretty sure i need a new pipe or get a pipe custom made i just dont know where to do so
either Batlground or TopSpeed can handle that for you. However, being that you're in Savannah, I don't know that either of those will truly be beneficial to you. You might wanna try SoJax in Jacksonville, FL.
Where is said clamp that keeps blowing off? I heard a few people complaing about pipes blowing off and they fixed it by buying a hump hose. This gives the pipes a little bit of movement so it won't take the pipe off when their is motor movement.
