what struts for a 2002 WRX Wagon?
Discussion in 'Modifications & DIY how-to' started by motomark, Sep 10, 2009.
  1. motomark
    motomark Loudest fuel pump Tucker
    Jan 20, 2005
    159
    I have V7 STI Wagon takeoffs + SPT springs + group N mounts. The left rear is shot. I am having great difficulty in finding affordable (less than $500) struts that fit the wagon. I have Koni inserts on my '05 Legacy GT which I like a lot but they are like $700 and you still have to cut up the strut. Only direct fitment I find is KYB GR-2, which are probably not up to the task of controlling the SPT springs.
    What are other members running?
  2. yerrow
    yerrow Active Member
    Jun 23, 2004
    1,340
    i run d-specs...just alittle more pricey than $500.
    save up more
  3. SubiNoobi
    Feb 5, 2006
    831
    Do the koni's. The install isn't that hard and they are great dampers.
    The only direct fitment is the KYB's that you found (maybe some KYB AGX's, but they aren;t much different), and no they will not have enough damping for your springs
    D-specs are great dampers, so I've heard, but they will give you camber issues on your wagon. Some people don't mind this, but others have ended up with severe positive camber that they could not adjust back to a safe range.
  4. yerrow
    Jun 23, 2004
    1,340
    i have zero camber issues on my wagon
  5. Alex
    If you just need something to hold you over I would find a set of stockers. Continue to save for a setup like the D-Specs.
  6. oneiguy
    oneiguy Active Member
    Apr 18, 2007
    1,162
    i have the yellows as well. its worth the lifetime warranty
  7. midnight_rider
    Mar 8, 2007
    289
  8. GTscoob
    Only issue with those, if you look at the part numbers, is that the front is for the older RSs and the rears are for bugeye WRX sedans. Its the classic mismatch that kinda works but still has some camber issues.
    Yerrow, what are you using to control your alignment? Camber plates, bolts, adjustable lateral links?
  9. yerrow
    Jun 23, 2004
    1,340
    nothing at all
