Emily and Me- 2000 Subaru Legacy
Discussion in 'Member Journals & Project Build Stories' started by LegacyLady, May 31, 2009.
  1. LegacyLady
    LegacyLady New Member
    So a couple of months ago I bought my girl. I've gotten really busy over the past couple of months with a new job and moving. But I've decided since I'm having problems with her, to start keeping a journal. I would like to mod her out as much as possible. Here is what she looks like.
    I'm open to any advice as to what to do to her to make her run better and look better. For now, My main goal is to get her running right and fix all the minor blips I'm having with her at the moment.
  2. oneiguy
    oneiguy Active Member
    welcome and gl
  3. LegacyLady
    As of next week, I am going to be replacing the valve cover gasket, knock sensor, right control arm, tie rod, Tune up, and oil change. The next things to be done is paint. As you can tell from the pictures, she hasn't been very taken care of on the exterior. She just needs a little TLC
  4. J_P
    Welcome!
  5. wrxin8or
    welcome to the boards
  6. XanRules
    XanRules Active Member
    welcome. I miss my Legacy.
  7. Trancetto
    The car is ugly so are you. Just kidding, nice car.
  8. Matt
    :slap:
    I see Emily....where are you?!
  9. rllyrckt
    rllyrckt New Member
    kinda OT but how do you like driving with the gear selector in the "pattern" that it is, as opposed to a straight up and down. i know its probably confusing, but im looking at retrofitting one of those gear selectors into my 2000 rs and just wondering if you like it or not.
  10. Alex
    Wirelessly posted (storm: BlackBerry9530/4.7.0.75 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
    Welcome :wavey:
  11. Mad Mallard
    Mad Mallard the mad mallard
    the gated 4eat?
  12. rllyrckt
    rllyrckt New Member
    if thats what its called then yes... do you know if it will work? or what i would need to make it work?
  13. LegacyLady
    So I haven't wrote in a while. Work has held me prisoner and unfortunately I haven't done much with her. I'm new to all this stuff as far as mechanical work is concerned. I did figure out how to replace the valve cover gaskets, and did it all by myself. YAY for me! :keke: I am having issues with the RPM shooting up and down on it's own. It idle's pretty low and unless I put the car in neutral while I'm at a stop light or spending extended periods of time at a stop it rattles and shuts down. :wtc: I was told that it's probably the map sensor, I found it on the strut tower on the passenger side (I think thats what it is) cleaned it with electrical cleaner, reset the code and Voila! my POC shut off and refused to crank for 15 minutes. It's kind of frustrating.
    Any helpful advice would be great. Please speak in lame man's terms. I'm an aircraft mechanic not a auto mechanic. I don't speaka the leet speak! :lol:
    I'm also looking to do an engine/tranny swap on it. I feel like maybe it's probably the best thing for me to do since she's got 170k miles on her. What I'm looking for there is what type of engine/tranny would be compatible and would actually fit, while giving me a boost in HP.
    Thanks guys.
    Much love,
    Legacy Lady
    *EDIT* For those wanting to know what I look like I have picture on my profile. If you want something a little newer, hit me on myspace or facebook
    www.myspace.com/tmj31206
    Search Tara Jaszczuk On FB! Add me!
  14. wagunz_pwn
    is the car still not cranking?
  15. LegacyLady
    oh no she's cranking. She just doesn't like to sit idle. If I'm idle in drive for to long of a period of time, she shutters then cuts off. but she usually fires right up. When I reset the check engine light I had issues with her cutting back on for like 15 minutes, but eventually she fired up. I'm at a loss as to what to do since I'm not mechanically inclined and can't really afford to take her to a mechanic. I feel bad for saying so, but I think I might scrap her and go for another subi. Probably the Impreza, or the Sti if I could get someone to teach me how to drive a stick shift.
    GOD I'M SUCH A GIRL!:pssh:
  16. Jake
    Sounds like a vacuum leak. Check all the hoses. You could very well have torn one and not noticed whenyou did the valve cover gaskets.
  17. LegacyLady
    The check engine light come on long before I did the valve cover gaskets, and the code is reading the map sensor. Would that cause the idle issue?
  18. WJM
    Did you ever fix this?
