Hello my name is matt and i just got my first wrx. the bottom end is damaged and from what i have read its best to just put in the 2.5 bottom end. the trans has been built and i would like to see arounf 400 hp daily driver. any help would be great! Thanks. also if any shops can help let me know I need to get this done very soon as this will be my daily car and I dont have anything till this is done
I guess what i am askin is what do i need to do to reach my goal. I dont know anything about this motor i am more of a honda guy. Thanks for the help
www.topspeedsales.com these are the go to guys for 2.5 liter swap. also, check out this thread: http://wrxatlanta.com/forums/showthread.php?t=23372&highlight=2.0+2.5
lots of venders on here that can help you out... basically if you have the money then 400 hp is no problem... your gonna be looking at upgrading turbo's, fuel system, intercooler, exhaust, and engine managment if you have not already... If you are looking to get running then you can look into getting the block and just the other necessary things to get started then upgrade later on....
