Clutch reccommendations for my build
Discussion in 'Modifications & DIY how-to' started by b reel, May 13, 2010.
  1. b reel
    So this morning I'm looking at the gaping hole where my motor use to be and see some metal shavings in the bell housing. Was hoping that my throw-out bearing had given up the ghost and after pulling my pressure plate and clutch off the flywheel, that wasn't the case. Seems that my pilot bearing committed suicide to the point that the ball bearings had embedded themselves into the clutch material and mauled three very distinct grooves into my pressure plate. All this and never had any slipping just a lot of noise, parked it when the noise went away which was the plan regardless.
    Now with a 2.5ish hybrid, a 5-spd dog box behind it and looking at maybe 5whp, what clutch and pressure plate would you guys go with? Don't waste your time with typing twin disc as that's out of the question.
  2. Alex
    ACT heavy duty street maybe? I am not sure how it would hold up at the strip with your dog box though.
    #2 Alex, May 13, 2010
  3. integroid
    I would get teh ACT Extreme duty PP and full face disk if they make the extreme PP for your build. That is what I have in my car and it is wonderful!
  4. b reel
    Started digging around after I posted, looking at going with South Bend. I've had good experience with them before. Just looking to see what other people are using
  5. Kokopelli
    I am/was running a southbend clutch on my car.
    Its an 8 puck feramic clutch and drives so much nicer than a 6 puck. Never really got to beat on it at the strip though and it looks like I never will.
  6. nicad
    Jun 4, 2007
    2,316
    you had me at gaping hole, cupcake
  7. b reel
    It's not pretty being that both inner CV boots had just recently shit all over the engine bay.
    Mike, the clutch disc was a South Bend, didn't realize they had that many options
    nicad, WTF?
  8. nicad
    Jun 4, 2007
    2,316
    got excited, then lost interest
  9. Alex
    Good opportunity to foam it up and clean it out :)
  10. MrCoffeeATL
    MrCoffeeATL Member
    Jun 13, 2005
    761
    hahaha thread saved
  11. b reel
    A thorough cleaning is in store followed by some detail work. We'll see what Ghost may suggest this weekend.
  12. Ben@TTR
    Ben@TTR Member
    May 21, 2007
    703
    :rofl: epic
  13. Trey
    Trey Active Member
    Mar 20, 2005
    1,322
    I had the ACT SB4-HDSS - Heavy Duty with Street Disc. It worked perfect with the OEM turbo and bolt-ons, 35% pedal increase.
    No need for anything else IMO, makes the pedal too stiff for a DD.
  14. Ballzo6
    Ballzo6 Member
    Mar 13, 2009
    14
    Ill make you an awesome deal on an extra twin disk I've got
  15. b reel
    sure throw it there, how much?
