FML, the saga continues...
Discussion in 'Modifications & DIY how-to' started by onemoresti, Aug 26, 2010.
  1. Cool_____
    OP is this oily smoke? Or is it vapor?
  2. onemoresti
    onemoresti Member
    I bought a NEW engine gasket kit for the 2nd assembly. I wouldn't say the smoke is "oily"...
  3. Cool_____
    Is this smoke on a cold engine or a warm one?
  4. Mike@TTR
    Warm one. It seems to develop more blowby as the engine warms up.
  5. Matt@Topspeed
    Matt@Topspeed Member
    Thats not a street engine, those ring gaps and clearances are setup for a race engine. Its a bit much for a street car.
  6. Cool_____
    Yeah that was built for a purpose wasn't it? Supposed to be a big boost drag engine right?
  7. 07Ltd#767
    not necessarily drag only, but that and track ready, yeah
  8. Matt@Topspeed
    Not drag only but the ring gaps and ptw are bigger than what I would put in a street engine. It was good on drews car.
  9. onemoresti
    onemoresti Member
    All I was really after was a solid platform that can take any abuse I was gonna give it. I probably jumped the gun a little on getting the block from Drew, but I wanted a built short block and he had one. It's running fine so far and I'm gonna deal with it, but I think I'm gonna build my old SB to suit me a little better. Still need to get it tuned though, probably sometime next week.
  10. Hopefully it will be better. WOW!
  11. Cool_____
    LULZ I saw your original response Andy. :rofl: I thought the same thing but kept my mouth shut.
  12. onemoresti
    onemoresti Member
    Joke's on me I guess?...
  13. Cool_____
    Just the mating surface of the heads isn't the greatest/smoothest. Did you do that?
  14. onemoresti
    onemoresti Member
    I went over it lightly with a rubber bristle 3M disc...
  15. Cool_____
    I think the flash of the camera makes it look that way.
  16. Matt@Topspeed
    Its to late now, but yeah you probably should have had those surfaced.
  17. Matt
    at least yours didn't look like this:
    :eek2:
  18. onemoresti
    onemoresti Member
    Not yet anyway...:sx:
  19. No, if you have never had someone tell you not to use any abrasives such as that, how could you know. I was not trying insult you, it's just when I see abrasive marks like that I know the problems they will create.
  20. onemoresti
    onemoresti Member
    I talked with the SOG techs and asked them what they used to clean off the heads when doing a HG job or whatever. 1 guy said he uses a little 1.5" thin green disc that I would say is more abrasive than what I used. He said even the Subaru Training Center instructors recommended to use the bristle pad I used. I realize that we're dealing with higher power levels than what Subaru has designed and intended these motors to for, and that's all the more reason for everything to be more precise. Only time will tell...
  21. Matt
    I wouldn't believe everything the training center instructors say...
  22. b reel
    When putting heads to a block using the steel head gasket you want the smoothest and straightest surface possible. When you torque the head down the gasket will only squish so much and if there is just the tiniest path for pressure to push oil or water out, well there's your failed head gasket.
  23. You should be fine, in the future use a good quality scraper that is free from burrs and nicks to retain the smooth finish of the part. MLS gaskets are not forgiving when it comes to imperfections in the mating surface.
