CAI idea will it make a difference?
Discussion in 'Modifications & DIY how-to' started by RSConvert, Oct 2, 2010.
  1. RSConvert
    RSConvert ɹǝuɹnʇpɐǝɥ uʞnɟɐɥnɯ ɐ sʇı
    Oct 5, 2007
    719
    Brainstorming!!!
    I have a fender mounted cai. I was thinking of putting the oem air duct intake back on (after modifying it a bit to fit around the aftermarket maf tube) to cover the big opening and possibly force "cooler" air, instead of the current heat going in from the engine bay. Will it make a big difference?
    EDIT: Here's a crappy BB pic I took after modifying and installing it
    #1 RSConvert, Oct 2, 2010
  2. yerrow
    yerrow Active Member
    Jun 23, 2004
    1,340
    theoretically yes
    realistically enough to feel a difference, probably not
    but worth a shot, sure
  3. Cool_____
    You will probably benefit more from cutting the duct to blow outside air directly onto the MAF itself. If it heat soaks the ECU will adjust.
  4. siegelracing
    Aug 19, 2004
    1,553
    Using the stock snorkel to direct "hood-height" cool air at the filter is a very good idea.
    Siegel
  5. Cool_____
    Yeah as long as the air flow from the snorkel isn't pushing into the filter in the direction of the intake itself! Remember the ram air issue that we never could figure out until WJM looked at the car? :rofl:
  6. RSConvert
    Oct 5, 2007
    719
    Thats what it's doing now after having to cut the duct to fit. Makes sense!!!!
  7. Doug@DBW Motorsports
    Jan 21, 2005
    1,359
    Stock air box intake system on the wrx and pre 08sti is the best system out there up to 360whp.
  8. RSConvert
    Oct 5, 2007
    719
    Doug anyway you can put my car back on the dyno to see if there are any added benefits? :rofl:
  9. Cool_____
    There won't be.....save your time. You are just keeping the intake temps cool.
  10. Trey
    Trey Active Member
    Mar 20, 2005
    1,322
    I thought everyone did that?
  11. davhul
    davhul New Member
    Feb 15, 2010
    2
    took my cai off and put oem box only on. sucks from the finder. never have a problem.
  12. Doug@DBW Motorsports
    Jan 21, 2005
    1,359
    One the dyno you will see no difference.. what you should do is monitor you air intake temps before and after the mods and see if they change.
  13. RSConvert
    Oct 5, 2007
    719
    Ok. Had my AP monitor it for a week (with and w/o the ram air duct) seems to be a ~10 degree difference with it installed. Not sure if it's a significant number but hey it's a little cooler and it was free.
  14. superdoughboy4
    Nov 19, 2009
    1,140
    ~10 degrees cooler for something you didn't pay for? I would say that's fairly significant.
  15. Trancetto
    Jul 9, 2008
    1,321
    I still have stock air box on mine. Had CAI before, but i bought a stock airbox on here. Didn't feel any loss from deleting the CAI. And I don't have to worry about CAI sucking water into my motor again.
  16. superdoughboy4
    Nov 19, 2009
    1,140
    It should be okay if you had the splash guard on, shouldn't?
    My CAI is fine, although my car is at stock height with the splash guard. I've driven through some really heavy rain, but I've never hydrolocked.
