Radiator Question
Discussion in 'Modifications & DIY how-to' started by John, Dec 18, 2010.
  1. John
    John Active Member
    Apr 13, 2010
    659
    I'll be doing an EJ20R with a vf39 swap into my Legacy soon.
    Will my stock radiator be sufficient or will I need to replace it with a bigger one?
    As well, I have a top mount intercooler sitting around the house. How much of a difference will a top mount vs a front mount make?
  2. Sparta
    with a vf39, not much
  3. AutoxSTi
    AutoxSTi Member
    Oct 28, 2009
    414
    It should but if you want to be safe, get an ebay one for $100 shipped. I got one and has been perfect since June of this year. The only issue you might have is the fitment of the factory fans. Just a slight bend on a couple of tabs to line things up and notching the holes bigger to allow perfect fitment of two fans would work. Also the threads on the fan screws might be different...Take it in to HD with you and figure out what thread patter they are and you can find out which ones work perfectly. I got the 2 core one...that's all you'll need. Also, before I forget, you will have to cut both the top and bottom hose just to make sure they don't hit the pulleys and no restrictions in the bends.
  4. Matt
    I'm pretty sure your stock radiator won't even work with the EJ20. you'll want a WRX spec radiator.
  5. John
    John Active Member
    Apr 13, 2010
    659
    What won't work about it? Too small, not enough flow?
  6. Matt
    if this image is truly of an EJ20R, the fill tank is attached to the motor, whereas, your radiator has the fill hole attached to the top of the radiator.
    I'm thinking you'll need a WRX spec radiator for it to work properly.
    here is what I found for a 97 Legacy GT motor:
    #6 Matt, Dec 19, 2010
  7. Mike@TTR
    Jan 12, 2009
    1,329
    Every seen the old Water to Air top mounts they used to put on subarus? Pretty cool stuff if you can find them.
  8. John
    John Active Member
    Apr 13, 2010
    659
    Matt,
    My car is currently like the second image, and the engine im getting is like the first image.
    I didn't think of the fill spot. Thanks for pointing it out
    I must say though, could you have found a more rusted out photo of the Legacy engine? lol shoot me if I ever let my engine bay look like that
  9. Matt
    that was the most complete looking engine bay I could find on GIS.
  10. John
    John Active Member
    Apr 13, 2010
    659
    here is a bit of a better one....mine lol
