Help, 06 sti tire to strut clearance issue
Discussion in 'Modifications & DIY how-to' started by gte123v, Jun 26, 2011.
  1. gte123v
    gte123v Member
    Apr 23, 2006
    310
    So I switched to coilovers and 255 tires on my stock bbs wheels. Everything fit fine except the passenger rear wheel. It's slightly touching the coilovers, all the other wheels/tires have about 4mm of clearance. I'm not really sure why only the 1 wheel is not working, can this just be tolerance differences from side to side? Never had a major impact on that wheel, with the exception curbing it once like 5 years ago. Anyone have any ideas?
  2. b reel
    alignment? bent lateral link?
  3. gte123v
    gte123v Member
    Apr 23, 2006
    310
    Nothing looks bent, and if the lateral links were bent, wouldn't that give me MORE strut to wheel clearance, not less? As for the alignment, that wheel does have more negative camber for some reason, but it's not adjustable. Should I just get some camber bolts or am I just putting a band-aid on a much bigger issue.
  4. WRboXer
    WRboXer Active Member
    Jul 23, 2004
    584
    An alignment is not a bandaid. If anything, it sounds like it's the main cause(besides the fact that you ballooned a tire on your 8" wheel). Camber bolts and re-align to a more performance oriented alignment. I suggest comething like -1 fr and 0 rear or -1.5 fr and -.5 rear, you may have issues with the fronts rubbing with to much neg camber.
  5. gte123v
    gte123v Member
    Apr 23, 2006
    310
    I have camber plates on all 4 corners, so changing the camber that way shouldn't cause any rubbing as it won't be changing the strut to wheel distance. However, to solve my current issue, I guess I would have to either go with a camber bolt or adjustable lateral links.
  6. b reel
    Depends if the douche who towed the car hooked a lateral link when tying it down on the roll back. That's the main reason they get bent so if in the past it's been towed look there first. Just a scenario...
  7. gte123v
    gte123v Member
    Apr 23, 2006
    310
    Never had the car towed since I bought it new in 06, of course, that doesn't rule out the scenario when it was delivered to the dealer. I guess I'll double check everything tonight to make absolutely sure that nothing is bent.
  8. WRboXer
    Jul 23, 2004
    584
    Ahh didnt realize you had camber plates.
  9. Alex
    Have you swapped the passenger front wheel to this location to rule out whether or not your wheel is "off"? Might as well start ruling bits out.
  10. gte123v
    gte123v Member
    Apr 23, 2006
    310
    yup, tried that already, definitely not the wheel.
  11. John
    John Active Member
    Apr 13, 2010
    659
    I run -3 all the way around on my camber with no issues. on 235/45/18
    Sounds like the OP has something bent
  12. WRboXer
    Jul 23, 2004
    584
    That info is irrelevant without offset and wheel size info fyi.
  13. b reel
    curbs and pot holes will cause havoc as well
  14. Alex
    Have put the car on a lift or on stands? You should be able to compare right and left a bit easier, without load on them.
  15. gte123v
    gte123v Member
    Apr 23, 2006
    310
    I checked both sides when it was up in the air, but I can do it again to make sure. I just checked the lateral links and they are not bent. At this point I'm ready to say its just tolerance difference from side to side, it is only just a 3mm difference afterall, and get a camber bolt in there to fix it :|. I do have the rear subframe locking bolts installed, maybe that shifted the assembly slightly?:dunno
    #15 gte123v, Jun 27, 2011
  16. yerrow
    yerrow Active Member
    Jun 23, 2004
    1,340
    i had a bent strut on the forester, apparently it had been bent for awhile and it just progressively got worse. but initially it was so slight that you couldn't see anything.
    it started out that i noticed that the tire rubbed the strut, then it got so bad that i heard a metal on metal sound when the corner was unloaded...it was rubbing on the wheel.
    switched out to a new strut and voila, no more scrubbing
  17. gte123v
    gte123v Member
    Apr 23, 2006
    310
    Finally figured it out! Apparently theres more slack between the lower struts bolts and the hub than I thought. I loosened them and gave it a good tug and voila, there was the 4mm of clearance I had on all the other wheels. So i did a simple calculation, basically there's enough play there to give you +-0.5 degrees of camber.
