WRXSS Swap and Build Log
Discussion in 'Member Journals & Project Build Stories' started by Mike@TTR, Mar 20, 2010.
  1. Mike@TTR
    Jan 12, 2009
    1,329
    Gone.
    #51 Mike@TTR, Jan 5, 2012
  2. bixs
    Mar 17, 2010
    597
    What size tubing did you use for mount? If someone were to bring in some steel would you bend it to specified angle?
  3. Mike@TTR
    Jan 12, 2009
    1,329
    It is a robust 1 5/8" chromoly tube and if I remember right .250" plate. Sent you a pm about bending.
  4. Mike@TTR
    Jan 12, 2009
    1,329
    Little update. The iron block 5.3 I was installing had a bit too much rust in the cylinder walls after honing for a 800hp motor, so we scrapped that and picked up an aluminum 5.3 shortblock and should have that put together in the next couple weeks. Hopefully the next month or two will get really interesting!
  5. Mike@TTR
    Jan 12, 2009
    1,329
    Got the chance this part weekend to clean the block up a bit and tear it all down. Cylinder walls looked mint as did the rings and pistons. Here it is after a nice hot bath.
  6. CelticPride
    CelticPride Banned
    Dec 1, 2011
    761
    Getting close!
  7. Mike@TTR
    Jan 12, 2009
    1,329
    Headlights are done! Big thanks to Alex!
  8. Mike@TTR
    Jan 12, 2009
    1,329
    gone.
    #58 Mike@TTR, Mar 4, 2012
  9. Mike@TTR
    Jan 12, 2009
    1,329
    Well plans changed a bit....old turbos are gone...new ONE is on order :)
