Power steering pump
Discussion in 'Allpro Subie Service & Performance' started by Dheim96, Feb 7, 2013.
  1. Dheim96
    Dheim96 Member
    Do you guys have a 06 WRX power steering pump in good condition laying around?
  2. RSConvert
    RSConvert ɹǝuɹnʇpɐǝɥ uʞnɟɐɥnɯ ɐ sʇı Supporting Member
    No sorry.
  3. yerrow
    yerrow Active Member
    and they're exspensive...only from dealership
  4. b reel
    seals are cheap if you have a leak
  5. Dheim96
    Dheim96 Member
    Ya, A quick search shows them at around $100. The dealership wanted $540 :eek2:
  6. liltoua
    liltoua Member
    I just rebuilt my brothers STI with new orings....not a drop of fluid and it's been 2 weeks now. Maybe you can try re-building it? If it doesn't fix it...at least you know you only spent $5 worth of oring replacements lol.
  7. Dheim96
    Dheim96 Member
    It's not leaking but making a horrible sound when I drive and turn the wheel. I think its pretty much done. lol
  8. sikwrx04
    sikwrx04 Member
    Mine is doing the same with a little leak, i ordered some o-rings and me and (liltoua) are going to attempt to rebuild it, if it still whins when at slow turns and what not then ill know ill have to by a new pump..or one from
    (Advance, Napa) etc....:|
  9. yerrow
    i'm in the same boat. i think its a dealer only piece, but i'm going to look tonite
  10. sikwrx04
    sikwrx04 Member
    What about the Remanf ones? Are those crapppy?
  11. wagunz_pwn
    make sure it comes with a warranty.
  12. Dheim96
    Dheim96 Member
  13. liltoua
    liltoua Member
    I wonder if they coated it black because the original pump was dirty as crap lol.
  14. sikwrx04
    sikwrx04 Member
  15. orndog
    orndog Member
    So warranted for life against manufacturer defects?
  16. Dheim96
    Dheim96 Member
    Basically as long as I have the car then they will replace the part under the warranty. Once I sell the car the warranty is gone and if the part failed then the new owner would have to buy a new part.
  17. orndog
    orndog Member
    The "great" thing about crappy parts with lifetime warranties is that if/ when they fail you get to do the labor all over again...
  18. goixiz
    goixiz Active Member
    I have an OEM rebuilt with "ALL" new seals. If interested let me know.
    I have researched the remanf ones and they do work, some of them do for a few months and some longer if you are willing to remove and install then you can take the chance.
    I also have the upgraded o-ring Kits with the shaft seal as well
  19. yerrow
    how much you want?
