Hi, my names Jeremy and I recently moved to Marietta. I currently work on cell phone towers for a living, and drive a 2002 White WRX with a LOT of mods. the easier to say the only thing left original to the car is the chassis and a few small interior pieces. She's currently just under 400AWHP daily driven.
Welcome! That much boost is intentional, right? You should post up a summary of your car! I'm sure there are lots of inquiring minds who want to know...
Yeah that's my target boost on the highest setting, since you asked I can get a list that covers most the main stuff. Motor: Ej207 v7 Jdm motor with working avcs forged rods and pistons (8200 rev limit) Deadbolt TD06 20G turbo 760cc deatchwerk injectors Perrin turbo inlet no name front mount intercooler AEM 5 gallon diesel truck meth kit running a 200PSI pump. Devils own methanol twin injection nozels with check valve AEM tru-boost controller AEM wideband AEM meth failsafe Tial 50mm bov Tial 44mm wastegate with screamer pipe Gruppe s manifold Gruppe s uppipe Invidia 3" Turbo back exhaust bellmouth downpipe Drivetrain: 07 STI long ratio 6 speed ACT extreme pressure 6 puck clutch custom made 3" aluminium driveshaft with hoop Sti axles Interior: Sti v7 front seats Sti rear seats Sti cluster Sti momo steering wheel Defi gauges (60mm match Sti red) Apexi turbo timer Pioneer double din avic-z2 Infinity 500watt RMS 4 channel amp, Infinity speakers all around, underwear woofer Exterior: V7 Sti front end V7 Sti hid projectors V7 Sti hood scoop Sparco wheels and BFGoodwrench Sport Comp 2 tires (which by the way are awesome tires, if anyones looking for new ones.) 04/05 Sti tails Suspension: Sti struts with tein S tech springs Front and Rear strut bar Bottom H Brace miscellaneous small parts and urethane bushings At the moment that's all I can think of, I'm sure there's plenty of other stuff I'm not thinking of right now.
It's the color they came from Sparco actually,They called it fusha or something like that. It's close to cherry blossom with a little more purple tone to it.
