Im going to be building an AR and have ordered a few parts. I have a question as far as assembling the lower receiver. Aside from the castle nut wrench, are there any "special" tools i need to assemble the lower? or can i make do with household tools? Thanks in advance!:clap:
i didn't need any drill bits. as long as you got a 100% lower (fully drilled/tapped/cut) then you shouldn't have to drill anything out. a small hammer (ball peen would be best) and vice grips were the only things i needed other than the wrench. never built or played with an AR aside from shooting one, and built mine in probably ~30 mins.
My bad, didnt mean to mislead. I used the drill bits to drive pins and center them. Ofcourse it only works with correct size drill bits. Gotta improvise. lol
Cool you have to remember Cookie's an eastern european redneck with an AK so drill bit, paper clip, soup can could be utilized for repairs
