Crankshaft timing gear help
Discussion in 'Modifications & DIY how-to' started by Ryan, Apr 23, 2014.
  1. Ryan
    Ryan New Member
    Mar 18, 2014
    I need help! So I took my old gear off to replace the crank seal. In order to take it off the gear comes off then the woodruff key will come out. To put the gear on do you put the woodruff key in the crank and then put the gear on, or do you instal the gear then the key? Some advice would be great lol! Btw it's a 06 sti
    Thank you,
    Ryan
  2. b reel
    clean, lube, key then gear
  3. Ryan
    Ryan New Member
    Mar 18, 2014
    Should it wiggle on or will I need to tap it on with a rubber mallet or something?
  4. Ryan
    Ryan New Member
    Mar 18, 2014
    Thank you! I got it on!!
