Doug's soon to be EPIC BRZ build..
Discussion in 'Member Journals & Project Build Stories' started by Doug@DBW Motorsports, Jan 18, 2014.
  1. superhawk28
    superhawk28 Member
    My coworker and Shringles paid $32k for theirs....markup?
  2. Tperk90
    Tperk90 Member
    damn major mark up...my limited was 28k too. Of course depending on time of purchase and miles
  3. digitizedsoul
    digitizedsoul Moderation is a vice Supporting Member
  4. superhawk28
    superhawk28 Member
    Granted both got special warranty coverage and all but we are getting way off topic now so I'm going to quit on that subject.
    Doug boost that thing on. How much bigger is the GT30R turbo than the Greddy one power wise? Looking for 400 hp?
  5. Matt
    Isn't there an FA20 in the new forester XT?
  6. Matt
    mine was with tax and other add ons like the rear underspoiler and extended warranty. :) I didn't have any other markup
  7. Doug@DBW Motorsports
    Sticker on my 2014 limited was 29.2k but I ended up paying 26.9k which was way under invoice and got a free 6 year extended warranty.. Lol. Perks I guess
  8. Sparta
    FA20 is also in the new WRX....
  9. Andrew@BallEngine
    Andrew@BallEngine New Member
    Lookin good Doug!
  10. dwx
    dwx Member
    Looks good. I need to get the rest of my STX crap installed so I can head over for a tune.
    Some speculate the VE drop in the low-mid range has to do with designing the car to have decent low-end torque at like 2500RPM for every day driving and then again at 4200RPM to redline, based on the cams/cam timing/etc. That's the optimist view. :) That's on a stock car, putting a header on and opening up the exhaust or an E85 tune can help eliminate it.
    The FA20DIT in the FXT/WRX was developed in parallel with this engine, but it's quite a bit different apart from being a 2L engine. The NA FA20 uses Toyota's DI system and the FA20DIT is all Subaru. It doesn't have port injection like the FA20. The addition of the port injectors definitely makes it easier to add more fuel, to date no one has come out with a replacement DI injector. DI helps with fuel economy and keeping detonation away, it's a 12.5:1 CR motor.
    I paid $27.5K for my BRZ in June of 2012 when it first came out, it's a lot cheaper than a STI...
    These motors seem to respond really well to turbos.
  11. Tperk90
    Tperk90 Member
    Any Updates?
  12. digitizedsoul
    Can't believe you wanted to paint that trunk doug. The carbon fiber would look so good against that red.
    Now that texas is behind ya'll, no scuses!
  13. slade1274
    'cept OLOA.....
  14. bullyhatch
    bullyhatch Member
    Managed to see this car on Saturday and WOW its a beast!
  15. dwx
    dwx Member
    What has been done to it?
  16. superhawk28
    superhawk28 Member
    Knowing Doug turbo'd and pushing powa.
  17. WRboXer
    WRboXer Active Member
    Doug's got a pretty interesting setup on his. 30r, non intercooled, 10-12 psi if i recall correctly from our conversation, running e85. I think he said it was at the 400whp range, really really cool.
  18. digitizedsoul
    now water to air intercooled.
    well over 500.
    i'll let him tell you though (if he ever does lol)
  19. dwx
    dwx Member
    I would certainly be interested in seeing the water-to-air IC system. I purchased a JDL turbo kit and it should be here next week but I'm not looking to install it for some time and still want to look at some other options.
  20. impreza
    impreza Member
    thats a nice looking red do you know what the colors is?
  21. Doug@DBW Motorsports
    I know I have been slacking on updating this thread so I will do my best to get everyone up to speed.
    Current mods :
    -TSM GTX3076 EQL 1.5scroll turbo kit
    -TSM quick pipe liquid to air intercooler
    -TSM 3" over/front pipe
    -TSM twin pump in tank fuel system with internal surge tank
    -TSM 1050cc injectors
    -Fuel Labs adjustable FPR
    -Amuse carbon trunk
    -STI front lip
    -Greddy Multi Da gauge
    -Tomei 80mm titanium catback
    -Omni 3bar
    -Delco AIT sensor
    -Ecutek RaceRom - TSM tuned with many custom maps and features
    -Enkie 18x9.5 +38 RPF1
    -245/35/18 Michelin PSS
    -ACT Street disc with HDD pp
    -PWR AWIC heat exchanger
    -Bosch IC water pump
    -cRAWFOrd AOS
    -JRZ COMP 2ways w/remotes cans
    -DEI turbo blanket and heat wrap
    -BREMBO brake kit front and rear (not installed yet)
    I think thats about it as far as mods go for now, I maybe forgetting something. Right now the car is making 440whp @ 14psi and 530whp @ 18psi both on E85. I don't know what the car makes on just 93oct as I have never filled the tank up with it. Lol... as soon as that free gas tank from the dealer was done I changed the oil and filled her up with E85 and never looked back. :eek:hnoes:
    Here are a few pic I just snapped quality sux... maybe I can get Rob to take a few real pics some day.
  22. Doug@DBW Motorsports
    I will get the dyno graphs up when I get to the shop later.
  23. superhawk28
    superhawk28 Member
    Wow that's awesome Doug. I'm guessing you removed the filter to show the ATW intercooler better?
  24. integroid
    Does your dog actually fit in the BRZ?
  25. Doug@DBW Motorsports
    No :(
    Also forgot to add motor is bone stock except a set of Kelford valve springs
  26. Doug@DBW Motorsports
    Actually haven't had time to finish everything and build the intake
  27. superhawk28
    superhawk28 Member
    Are the stock springs a weak link?
  28. dwx
    dwx Member
    Very cool, was still planning to stop by tomorrow to check it out in person.
  29. slade1274
    Curious as to the "budget range" for what a build like this would run.....
  30. Doug@DBW Motorsports
    Really depends on what kind of parts you choose to use.. but this is a close breakdown of whats on mine.
    Power mods and a clutch would be around $6500 parts only.
    The JRZ Comp 2ways are $5875, then add in adjustable bushings and misc suspension bits for another $550. Complete set of used STi brembos with lines pads $1000.
    Finally the looks department--- wheels, tires, front lip, trunk are roughly another $3000
    Total = $16,925 'ish
    Obviously it could be done for less....
  31. Doug@DBW Motorsports
    Yes for FI and high rpms
  32. WRboXer
    How many miles on the FI setup so far man? Still liking the FA so far? Love the story of this little motor.
  33. slade1274
    That was an almost perfect summary for me Doug!
    Just contemplating what my next project will be- BRZ to mod or wait for that new M2. I doubt I would go as far as you did with the suspension- upgraded shock/strut and springs would probably suffice for me, but the power mods look very interesting. Strict E85 would be tough for me, but I also think 350whp would be sufficient- by your numbers that may be doable on 93 pump.
  34. Doug@DBW Motorsports
    I just cracked 2500miles total on the car. 1500 of those have been FI.
  35. Doug@DBW Motorsports
    Yea... I actually had swift springs on my stock struts at first and it was fine. I think on 93octane which I am going to tune it on soon should make 380ish
  36. Doug@DBW Motorsports
    Dyno numbers are just that... so this morning I decided to take a spin with the Vbox running and get a 60-130 time. FWIW I have no idea what the stock BRZ will run 60-130mph but I imagine it would be SLLLLOOOOWW like 15-20 seconds if not more.
    Anyhow... on my daily high map I was able to run 7.33 second 60-130. Pretty sure with more boost and some sticky tires I can get the brz down into the 6.9 range. Very impressive for an otherwise stock motor.
    STOCK GTR RUNS 9.4 60-130 fwiw
    vbox
  37. Doug@DBW Motorsports
    few more shit pics I had on my phone of the header build...
    Crappy cell phone pics I took with it all tacked .. but you get the idea
    and photo bomb of the revworks header being used to back purge :)
  38. dwx
    dwx Member
    I talked with Mike the other day and took a look at the car when you were busy. Definitely a cool setup. Liike I said on my PM on the other forum oddly enough my old WRX top-mount AWIC would fit with the setup with some minor tweaking of the inlet/outlet and of course new brackets. I have some reservations about AWIC but it might not be nearly as bad with the core sitting away from the heat versus directly on top of the engine. I even mocked up my old heat exchanger and it would work on the BRZ as well. I used to use a 2 gallon Igloo cooler with quick disconnect fittings mounted in the trunk for a reservoir. I had two of them so I could swap them between autocross runs...
    However the JDL kit I've currently got moves the turbo over to the right too much, I would need a header like the one you are using to keep the turbo in the middle. Any chance of you guys making/selling the hot parts? (header and down pipe/overpipe)
  39. transition
    transition New Member
    I had to create an account just to say incredible work Doug.
  40. integroid
    For the right amount of money I am sure he would sell you the shirt off of his back. Anything can be done for the right price:)
  41. dwx
    dwx Member
    Haha of course. Mike alluded that there wouldn't be a "TopSpeed" turbo kit for the BRZ and I don't really blame them, the market is flooded with both good and bad kits at this point.
  42. integroid
    If topspeed doesnt have the time to build you the hot pipes, PM me and I can send you to someone that can.
  43. Brock Samson
    Brock Samson Member
    Very nice work, as usual, Doug. Car definitely looks mean!
  44. superhawk28
    superhawk28 Member
    So is it officially built motor time and some serious boost (10-12 more psi)?
