Air-to-Water Intercooler Set up!
Discussion in 'Modifications & DIY how-to' started by jonnyboy0150, Nov 30, 2005.
  1. jonnyboy0150
    jonnyboy0150 Member
    Mar 2, 2005
    712
    My buddy Arnold (i dunno if he is on the site yet) that i work with will soon be running an air-to-water intercooler setup on his WRX!! He has already bought and mounted a massive front heat exchanger. He already has a new spearco air to water intercooler and 30 feet of lines. The only thing he lacks is a pump and tank (he may use the washer bottle) and he needs to figure out how he is going to mount it and then have some piping made.
    Im interested to see how it will compare to the conventional air to air setup. Ill keep you guys posted on how goes!
  2. married05gt
    married05gt starting over
    Feb 4, 2005
    483
    Yeah. I saw him at SOG and he showed me the progress so far. It looks like it's going to be a pretty good set up. Car is going to be a beast.
    P.S The car he is working on is Gary's old suby.
  3. jonnyboy0150
    jonnyboy0150 Member
    Mar 2, 2005
    712
    Yeah i know, Gary's got a Legacy now too! He blew the old motor up, the bottom end is now built (2.0 liter still). So it should be able to handle quite a bit of power!
    Yeab that intercooler setup is gonna be crazy! It should cool just as well as a FMIC if not better, plus the fact that its short piping! So very little lag increase.
  4. CROSSeyed
    CROSSeyed Member
    Aug 31, 2005
    149
    I'm not sure I fully understand this concept... got a couple thousand words to illustrate? (pics?)
  5. jonnyboy0150
    jonnyboy0150 Member
    Mar 2, 2005
    712
    hold on ill go find some...
  6. jonnyboy0150
    jonnyboy0150 Member
    Mar 2, 2005
    712
  7. Weapon
    Weapon 90lbs of dynamite
    Jan 29, 2005
    6,875
    wow..thats sounds awesome! keep us updated
  8. siegelracing
    Aug 19, 2004
    1,553
    I think we're going to dyno the present stock WRX tmic tomorrow morning to compare against.
    We will be able to run a LOT more boost through that air-water IC though...
  9. jonnyboy0150
    jonnyboy0150 Member
    Mar 2, 2005
    712
    Arnold got some baseline runs in before the intercooler to compare before/after numbers. He put down i think 268hp 270tq after some tuning adjustments from SS.
  10. miloman
    what turbo is he running?
  11. jonnyboy0150
    jonnyboy0150 Member
    Mar 2, 2005
    712
    VF34. Surprisingly, he has a HKS downpipe with no bellmouth. I figured that would hurt his numbers a little.
  12. miloman
    what other mods does he have right now?
  13. jonnyboy0150
    jonnyboy0150 Member
    Mar 2, 2005
    712
    UP, DP, hks catback (my old one), injen CAI, built bottom end, exedy clutch, vf34, bigger injectors, walbro pump, and maybe some other little stuff. Oh and ecutek of course.
  14. siegelracing
    Aug 19, 2004
    1,553
    We could have made more but that stock WRX TMIC is just not very big....
    We have planned all along on upgrading the IC system, so there was no need to push hard on the stock WRX TMIC...
  15. moose
    Feb 5, 2005
    2,969
    What air/water intercooler is he using? Spearco?
