Mr. Smith's 2008 WRX
Discussion in 'Member Journals & Project Build Stories' started by Tank, Sep 10, 2012.
  1. Wycked304
    Wycked304 New Member
    it's a slot car track
  2. Tank
    Tank Member
    No that is 1/32 scale slot car track. It is the only way I can have most every car that I want. You know what regular guy has 6 NSX, 2 Skylines, 5 Corvettes, 16 Porsches etc. It's fun. There are a couple of folks here at the office that race. Then their is the big track at Sugarloaf Mill Mall.
  3. Tank
    Tank Member
    Well I got the fender rolled and that resolved my rubbing issues in the rear the front is fine. Now it is time for a minor brake upgrade being that it is time to replace the brakes anyway. My plan it to go with the '07 Front 4 piston calipers, new rotors at all four corners and some power stop pads. I'll be doing the parking brake pads as well. When I get a little more money put away I will upgrade the rear to the two piston setup. I think this will do the trick especially with the NO budget to make changes. Let me know what you think.
