October 22nd, 2016 - Spun rod bearing. January 5th, 2017 - Parts ordered. ARP Head Stud Kit 11mm Exedy Stage 1 Heavy Duty Organic Disc Clutch Kit Gates Racing Timing Belt Kit Group-N Pitch Stop Mount Group-N Engine Mount LH Group-N Engine Mount RH Group-N Transmission Mount IAG Black CNC Top Feed TGV Deletes IAG Performance Street (AOS) IAG Stage 2 Tuff shortblock Killer B Motorsport Aluminum Oil Pan Killer B Motorsport Oil Baffle Windage Tray Killer B Motorsport Ultimate Oil Pickup NGK plugs OEM oil cooler Subaru 2.5L Oil Pump Subaru OEM Full Gasket And Seal Kit Subaru OEM Thermostat SMY Dual gauge Cluster ProSport Evo Oil Pressure Gauge ProSport Remote Oil Pressure/Temperature Sender Install Kit Mishimoto Oil Drain Plug M20x1.5 January 13th, 2017 - All parts received, Time for the build to start.
