We have Meth Kits in Stock!!!
Discussion in 'TopSpeed' started by Tray@topspeed, Dec 20, 2005.
  1. Tray@topspeed
    Tray@topspeed Member
    Jul 1, 2005
    320
    We have Meth kits in stock!
    Hey guys after much work and testing we are finally ready to release our meth/alky injection kits. These kits are trunk mount and have a 7qt tank which is almost 2 gal. larger than any meth kit on the market right now. The kit also has a low level warning light and spray light to let you know that everything is working properly. Also they run a 2d scalling based off your maf sensor to allow you to tailor the exact flow of meth needed. Also include are two different size nozzles for the hp output of your application. Installation is easy and straight forward usually taking the avg wrench a few hours to install.
    I am hoping to have pictures up in the next day.
    Price is $479.99
    Tray M
  2. Tray@topspeed
    Jul 1, 2005
    320
    Also there is an added feature with our kit if you decide to purchase it.
    For years, many have wanted to use water/methanol injection but have not taken advantage of the power increases do to safety concerns. Designed as an ad-on to the water/methanol injection system, Safe Injection™ provides for a safe tune in those instances where no injection is present and an aggressive tune is utilized.“ This system reduces boost or timing anytime injection quantity goes below a set point (e.g. if reservoir level goes too low) making the tune instantly conservative for the ultimate in safe water/methanol injection.
    Operation
    The SI-10 and SI-05 monitor the flow of Water/Methanol in the system. When flow drops below 0.10 Gallons per Minute (GPM), equal to 378 ml/min,( 0.05 GPM or175ml/min on the SI-05) the fault trigger will go to a high state of 12 volts. In addition to the supplied red LED, this trigger can be used to signal the following:
    1. an ignition/timing controller such as an MSD timing computer if using an MSD ignition
    2. aftermarket engine computer
    3. a solenoid such that boost is reduced in a wastegated turbo set-up. or turns off the boost controller giving you a lower boost seting from the wastegate spring.
    4. The trigger signal can deliver up to 1.5 amps to drive a solenoid or relay
    the option is an additional $99.99
  3. dlowman
    dlowman Member
    Jan 18, 2005
    293
    Don't do it guyss!! they will get you addicted to meth, then keep you coming back for more.. It will be a never ending addiction! Save yourself's Run away!
    p.s.
    I will be by later to pick up some more Tray lol
  4. Tray@topspeed
    Jul 1, 2005
    320
    hahaha See you soon!
  5. JJang12
    Aug 17, 2004
    803
    Does this have progressive injection like SMC?? or more like switch on/off @ xxpsi type?? wat psi does "PUMP" pump out to injector??
  6. Tray@topspeed
    Jul 1, 2005
    320
    Yes it is a Progressive injection. and the pump pumps out 150psi.
  7. JJang12
    Aug 17, 2004
    803
    hmm.... very very tempted :drool: :drool:
    trey, PM me about any hook up for installation & ecutek tuning. If it's good deal dat i can't resist, i sell my SMC and buy topspeed version.
  8. JJang12
    Aug 17, 2004
    803
    tray, any new pictures of top speed meth kit??
  9. 05impreza
    05impreza Member
    Dec 30, 2005
    39
    very interested to see pics......
  10. SolidSnake
    SolidSnake Member
    Jan 23, 2006
    40
    Do you have any pics yet?? Would you say you kit it equal, or some what more advanced to SMC?
  11. Alex
    Not to speak for them, but it seems like their kit is close to SMC, except their tank is TWICE the size of SMC's.
  12. rolling_trip
    rolling_trip Active Member
    Feb 21, 2005
    1,217
    i'm in the market for a meth kit, do you have any pics yet
  13. bigb996
    Jul 5, 2005
    2,403
    7
    once i get some ecutek and bigger turbo/intercooler you can be assured i will be picking one up.
