Porting the wastegate on 04 STi
Discussion in 'Modifications & DIY how-to' started by Alex, Dec 25, 2005.
  1. Alex
    Anyone know how much this would cost from Deadbolt or such? I'd love to ensure that I never see boost creep again. Especially after my experience at Little Tally this past Thursday.
  2. miloman
    contact jerry... link to their page
    what happened at tally?
  3. moose
    Feb 5, 2005
    2,969
    May as well do a full P&P if you are going to take it off anyway. I would guess around 200 bucks.
  4. Alex
    Well I had a blast, but first 3 runs were learning to shift around boost creep :wtc: By the end of the day (4th and 5th run), I had it down. It was just so cold there (<30 degrees) that my poor car with the full 3" out sans EM was having some trouble. This equated to me never being able to hit full throttle.
    P&P doesnt seem worthwhile on the vf39, however, ceramic coating does.
  5. miloman
    didnt u say u were gonna get ecutek'd sometime in december?
  6. Alex
    Yes, or early Jan :bigthumb:
  7. miloman
    ooooh..... dirty dirty :naughty:
  8. Alex
    Wish you were here for it :wtc:
  9. JJang12
    Aug 17, 2004
    803
    deadbolt won't do porting wastegate due to common crack issue of vf39.
  10. blink
    blink Member
    Sep 28, 2005
    287
    what is boost creep?
  11. miloman
    u experience boost breep when under load, the boost 'creeps' up towards +infinity fairly quickly...
    here's my understanding of what causes this... someone correct me if im mistaken
    exhaust gases flow over the turbine on the hot side of the turbo causing the turbine to spin... this spins the turbine on the cold side through a shaft and builds boost... the wastegate (on the hot side) can be opened to allow exhaust gas to bypass the turbine in order to control boost... if the wastegate can't flow the desired amount of gas, then more gas flows over the turbine and builds more than desired boost
    #11 miloman, Dec 29, 2005
  12. Alex
    sounds correct. once the build up is too great, the ECU attemps to correct by cutting fuel to the engine (instant stop) and you have a sudden surge, causing an extreme (but very short) period of leaning out the engine.
  13. Trey
    Trey Active Member
    Mar 20, 2005
    1,322
    There was a HUGE thread on NASIOC on DIY that had pics and exactly where to remove the material.
    You can do it yourself with a dremel. Takes no more than 10 seconds once the exhaust side housing is removed.
    Mine works great.
    Also, All that cracking talk is pointless.
    No one has proven that they have a loss in performance because of a hairline crack either. ;)
    #13 Trey, Dec 29, 2005
  14. Alex
    Trey would you be interested in giving me a hand at some point ? Perhaps during the install day? :bigthumb:
  15. wrxguy
    wrxguy Member
    Nov 3, 2005
    467
    Boost creep is rising boost due to not enough exhaust bypassing the housing.
  16. Trey
    Trey Active Member
    Mar 20, 2005
    1,322
    ...hence enlarging the opening. lol
    Sure Alex, you take it off and I'll show you where to remove the material, hell I'll do it if ya want. It's easy. :)
  17. Alex
    Alright man, I may have to take you up on that offer.
