Bad gassy smell after exhaust buzz noise...
Discussion in 'Modifications & DIY how-to' started by MrCoffeeATL, Jan 18, 2006.
  1. MrCoffeeATL
    MrCoffeeATL Member
    Jun 13, 2005
    761
    So like the title says, i had a few incidents where my exhaust made a ping/buzzing noise for a few seconds when i was driving along at a brisk pace. I thought nothing of it till today when i noticed my car smelled like gas, despite being on for close to 30 minutes. I only have one cat (in the cobb downpipe) so i understand that it might smell a bit before it warms up but this has me a little worried. My A/F is fine now so the car should not be dousing the cat in unburned fuel.
    Is there a way to check to see if the catalytic converter has died by just looking at it or do i actually have to poke it with a wire to see if it comes loose easily?
  2. moose
    Feb 5, 2005
    2,969
    If you can still read your rear O2 sensor (i.e. don't have a mechanical fix) it might be worth seeing what it says.
  3. Alex
    is this during idle?
    hah, also, I read the title orginally as "bad grassy smell" and was like :confused:
  4. MrCoffeeATL
    MrCoffeeATL Member
    Jun 13, 2005
    761
    good call on the rear o2, i'll see what delta dash says. Any idea what resonable values might be for a single cat?
  5. married05gt
    married05gt starting over
    Feb 4, 2005
    483
    I also have high flow catted DP. At full throttle I get a winning noise and the same smell some times. Mine is simply because of an UP leak. I just to busy to fix it right now.
  6. MrCoffeeATL
    MrCoffeeATL Member
    Jun 13, 2005
    761
    My smell is at idle, usually when i come to a stop. I'm going to check tomorrow with delta dash when i don't have so much class stuff to run to.
  7. Alex
    Its possible that you simply run a tad rich during idle, even more so after you've been driving. As a catless, 3" out owner w/o EM, my car is quite gassy at idle.
  8. MrCoffeeATL
    MrCoffeeATL Member
    Jun 13, 2005
    761
    well with my car running like crap even after trying all 3 gas stations near school here in ohio, i went about a half hour south and got gas near a friends place. My smell and my bad performance have resolved themselves. I figured it could not be gas related since i tried 3 brands (2 local and shell). Guess the gas here at school is poor at best. Wierd huh. It was never a problem in atlanta because i can always use the shell near me.
  9. Alex
    I didnt even think of that. Good point though. It's more than possible that they're gas is crap.
  10. MrCoffeeATL
    MrCoffeeATL Member
    Jun 13, 2005
    761
    bah, it came back on the same tank of gas so i just sent of a datalog to SS to see if he can tell what's wrong. It sucks to be so far away from a decent tuner.
