Posible tuning problems
Discussion in 'Modifications & DIY how-to' started by lowflyingwrx, Jun 6, 2006.
  1. lowflyingwrx
    lowflyingwrx Member
    Good afternoon all... This past weekend I did a few dyno pulls on my wrx. I am a little disappointed and was wondering if my numbers are off or if I was expecting too much. 195.3 whp and 183 lb/ft torque. Kind of weak in my opinion. I was told it was running very rich and needs to be tuned. The reason for my concern is I see all over different boards that people with Cobb stage 2 are in the 220's and 230's on the base stage 2 map. Could my reason for low numbers be because I am still using the 3rd cat? I know it’s a shot in the dark trying to diagnose the problem but any Ideas would be very helpful. Posted below is my parts list.
    2005 Wrx
    Parts list-
    Cobb stage 2x93 oct map
    gutted up-pipe
    bosal shorty downpipe
    2.5inch cat back(still have 3rd cat)
    perrin IC hoses
    I did my 3 pulls on a dynopack dyno.
  2. Weapon
    yea those numbers seem low. where did u have it dyno'd?
  3. yerrow
    yerrow Active Member
    i made 219/220 at TS with the OTS stage 2 map
  4. 1ll-WRX
    I haven't gotten dyno'd since my OTS stage two but before I dyno'd 218/220 at TS....
  5. Suby1128
    Suby1128 Member
    keeping the third stock cat, with the Cobb Stage 2 I was getting 227 whp and 224 wtq. Your numbers do seem a little know, I'm not sure why that could be, running rich wouldn't do that.
    Craig
  6. Alex
    Did you happen to take a peek at the advanced multipler? You could possibly just be running shotty gas.
  7. SonicBoom
    I hit 232whp, 237tq with stage 2, even with a cold air intake robbin power...
  8. JJang12
    make sure you don't have any leak. (boost, exhaust, vaccum) Also stock 3rd cat won't rob high whp to be noticed. I made 223/227 when i was cobb AP stage 2 w/ stock 3rd cat.
  9. lowflyingwrx
    lowflyingwrx Member
    Thanks for the reply's guy's! I did my dyno runs on Knowledge’s dynopack. I always fill up at shell or BP. I think it was shell the night before. I will go back through today and check for leaks. If that does not work is there a local place that can tune through the AP or find out the posible problem. I live up in Cumming GA.
    Thanks again for the help!
  10. SonicBoom
    Topspeed is off of exit 12 on 400.... Should be pretty close. They have Protuner now too :)
  11. lowflyingwrx
    lowflyingwrx Member
    Thanks, I will have to check them out. I have heard good things about them.
  12. FrankenSTI
    FrankenSTI Member
    I also live in cumming, where about do you live? I have been to topspeed, and SOG I would highly reccomend going to see Scott at SOG.
  13. lowflyingwrx
    lowflyingwrx Member
    I live off of 20 about a mile past suwannee dam rd.
  14. FrankenSTI
    FrankenSTI Member
    Damn your right neat me i live in Preston Pointe at Windermere.
  15. miloman
    see if u can get the ECU logged... tari has a free logger but u need a cable... maybe someone here could hook u up
  16. Cool_____
    The Accesport cable works with the Tari.
